Serout problem
Results 1 to 40 of 95
Thread: Serout problem
Threaded View
  1. #33
    Quote Originally Posted by lerameur
    O k starting from scratches..
    I manages to do 2 different programs which dont work.
    here: http://www3.sympatico.ca/lerameur/
    do I need to configure SSPCON, or the RCSTA registers ?
    Also in your RX4.bas (maybe it was RX6.bas), you have
    Serin PortB.3, 16780, [B0]
    ----shouldn't that be serin2?
    I tried both , so many combinations....
    k
    Did you get the LEDs to light up in sequence as described in the earlier post?
    And if you didn't, then why are you worried about the SSPCON or RCSTA registers... and why are you worried about those 2 registers in the first place? You're using a software-based serial commands, not hardware.
    Priorities, man, priorities....
    And after further checking.....................
    If you'd check your ttt program and read the PIC datasheet, you'll notice that RA.4 is an open-drain output...you'll never get a high logic level from it...
    If you'd check your rrr program and read the PIC datasheet, you'll notice that the TRIS statements are wrong...
    Don't assume something is broke when you just plain haven't looked hard enough... Come on,,, get on it... Get this thing working by tomorrow!!! or else!!!
    Last Post: - 8th March 2010, 21:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 17:46
    Last Post: - 13th December 2008, 18:11
  4. Strange SerOut Problem
    By masosi in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2007, 07:06
  5. Replies: 11
    Last Post: - 13th July 2005, 20:26
