Serout problem
Results 1 to 40 of 95
Thread: Serout problem
Threaded View
  1. #11
    Sep 2006
    I tried ansel =o all you told me, and remove the boatloader. Dont even know why it was there. There is no change in the system .
    If I am sending $aa on the tramsitter pic, shouldn'y I get that also on the LCD on the transmitter?
    I have four output on my transmitter. Here is your code to with only four values, the rest I didnot change it. None of the leds are lighting besides the initial feed:
    'RECEIVER CODE
    DEFINE OSC 20 '20Mhz Oscillator was used
    Include "modedefs.bas" ' Include serial modes
    ADCON0 = 0 'AD MODULE OFF & CONSUMES NO CURRENT
    CMCON = 7 'COMPARATORS OFF
    TRISA = $00 : TRISB = $FF 'all porta is outputs, all portb is inputs
    B0 var byte
    'testing led outputs
    porta.0 = 1 : pause 200 : porta.0 = 0
    porta.1 = 1 : pause 200 : porta.1 = 0
    porta.2 = 1 : pause 200 : porta.2 = 0
    porta.3 = 1 : pause 200 : porta.3 = 0
    start:
    B0 = 0 'empty B0 because the program doesn't
    serin PORTB.3,n2400,[B0] 'if n2400 doesn't work, try t2400
    if B0 = $AA then ledson 'manchester encoded $f
    if B0 = $55 then ledswing 'manchester encoded $0
    if B0 = $5a then led1toggle 'manchester encoded $1
    if B0 = $65 then led2toggle 'manchester encoded $2
    goto start
    led1toggle:
    if porta.0 = 1 then
    porta.0 = 0
    porta.0 = 1
    goto start
    led2toggle:
    if porta.1 = 1 then
    porta.1 = 0
    porta.1 = 1
    goto start
    ledson:
    porta.0 = 1 : porta.1 = 1 : porta.2 = 1 : porta.3 = 1
    goto start
    ledsoff:
    porta.0 = 0 : porta.1 = 0 : porta.2 = 0 : porta.3 = 0
    goto start
    ledswing:
    porta.0 = 1 : pause 10 : porta.0 = 0
    porta.1 = 1 : pause 10 : porta.1 = 0
    porta.2 = 1 : pause 10 : porta.2 = 0
    porta.3 = 1 : pause 10 : porta.3 = 0
    goto start
    Last Post: - 8th March 2010, 20:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 16:46
    Last Post: - 13th December 2008, 17:11
  4. Strange SerOut Problem
    By masosi in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2007, 06:06
  5. Replies: 11
    Last Post: - 13th July 2005, 19:26
