I had time to analyze the code:
A few questions came up:
For the ledtoggle, why would you want to bit the pin high to low and then put it high, why not put it high right away. The way you have it, if its high, you put it to low, then to high, there must be a reason why and its flying 100 feet over my head.
Also, the led will stay on until you call the ledsoff right?
as far as the manchester coding goes, I understand, but there is decoder done here, you are simply pointing the coded values to their function. right?
k
