Changing declared variables names on the fly
Results 1 to 16 of 16
    jessey, This should save you a few bytes......
    _On con 1
    COUNTER VAR BYTE
    Timer_Is var byte[13]
    Clock_Mode var byte
    On_Am_Pm_Mode VAR BYTE[13]
    Hours VAR BYTE
    On_Timer_Hour VAR BYTE[13]
    Minutes VAR BYTE
    On_Timer_Min VAR BYTE[13]
    Seconds VAR BYTE
    On_Timer_Sec VAR BYTE[13]
    Check_The_Timers_Relay: 'this code uses 1404 bytes
    COUNTER = 1
    WHILE COUNTER < 13 'LOOP 12 TIMES
    IF Timer_Is(COUNTER) = _On then
    IF Clock_Mode = On_Am_Pm_Mode(COUNTER) THEN ' this checks the am/pm mode for on Timer
    IF Hours = On_Timer_Hour(COUNTER) THEN
    IF Minutes = On_Timer_Min(COUNTER) then
    IF Seconds = On_Timer_Sec(COUNTER) THEN
    GOSUB Turn_On_The_Relay
    IF Clock_Mode = Off_Am_Pm_Mode(COUNTER) THEN
    IF Hours = Off_Timer_Hour(COUNTER) THEN
    IF Minutes = Off_Timer_Min(COUNTER) then
    IF Seconds = Off_Timer_Sec(COUNTER) THEN
    GOSUB Turn_Off_The_Relay
    COUNTER = COUNTER + 1
    WEND
    jessey's Avatar
    jessey Guest
    Default Thanks Dave, could you explain
    Hi Dave,
    I'm not familiar with "var byte[13]" or how it works but I'd really like to understand it as I would Sayzer's code example, I have a real thirst to learn PBP and this forum is a great opportunity for me.
    The attachment shows all of the variables for one timer and all the necessary subroutines that are shared by all of the 12 timers except for some sub's that are used to select prints to show to the Lcd and a repeat On/Off timer. The Set_Timer_1: subroutine is repeated 11 more times and they all share the same sub's in the attachment, that'll give you a good idea of what I'm working on. If you have the time to explain the process using "var byte[13]", maybe something simple that'll flash an Led or just some theory then I'd love to see it.
    jessey
    Jan 2006
    Istanbul
    Jessey,
    Check these and see how array works.
    http://www.picbasic.co.uk/forum/showthread.php?t=544
    http://www.picbasic.co.uk/forum/showthread.php?t=3753
    Then have your questions either in those posts or here.
    jessey's Avatar
    jessey Guest
    Default Thanks Sayzer
    Hi Sayzer,
    Yes I found Melanie's thread a while back and I even wrote a short simple program to try and understand it better. I got the program to turn on an led whenever the bits equaled 1 and to shut it off when 0 and with the press of a button the sequence changes but I couldn't figure an application for it in any of my programs. I'd still be interested in hearing Dave's concept as it seems he can see an application that's beyond my comprehension and I'm eager to learn that.
    Thanks for your explanation of the eepron and it does make sense to me for that part now. I did read the manual but couldn't make any real sense of it. This is just a hobby for me, I haven't had any courses or schooling on programming or electronics so I take it slowly. Now that I'm semi retired I've started to spend more time with electronics and programming and I find it very rewarding.
    Thanks for your help and the links
    jessey
    Select_Push_Button   VAR PORTB.7          '(pin 40)  1st
    Hours_Push_Button VAR PORTD.2             '(pin 21)  2nd
    Minutes_Push_Button var PORTB.0           '(pin 33)  3rd
    Seconds_Push_Button var PORTB.1           '(pin 34)  4th
    Toggle_Push_Button var PORTB.2            '(pin 35)  5th
    A VAR BYTE
    A = 0
    MyWord var word
    MyWord = %1010101010101010
    MyByte Var word
    MyVar var word
    MyBit var BIT
    Reference_Word  VAR WORD
    Reference_Word1 VAR WORD
    Reference_Word2 VAR WORD
    Reference_Word3 VAR WORD
    Reference_Word  = 1010
    Reference_Word1 = 1010
    Reference_Word2 = 1010
    Reference_Word3 = 1010
    Is_Pressed CON 0
          GOTO mainloop
    Sound_Buzzer:
          PWM Buzzer,250,1
    PAUSE_100:
          PAUSE 100
     mainloop:
     Show_Print:
     For MyVar=0 to 15
       MyBit=MyWord.0(MyVar)
       LCDOut $FE,1,"Bit ",DEC MyVar,"=",DEC MyBit
       LCDOut $fe,$c0,$fe,$0e,dec Reference_Word,DEC Reference_Word1, _
                         DEC Reference_Word2,DEC Reference_Word3
       if a = 1 then Return_To_Push_Button_1
       if a = 2 then Return_To_Push_Button_2
       if a = 3 then Return_To_Push_Button_3
       if a = 4 then Return_To_Push_Button_4
       if a = 5 then Return_To_Push_Button_5
       IF MyBit = 1 then
        HIGH LED
        PAUSE 1000
        LOW LED
        PAUSE 1000
       IF Select_Push_Button = Is_Pressed then ' #1
        GOSUB Sound_Buzzer : A = 1
        MyWord = %1100110011001100
        Reference_Word  = 1100
        Reference_Word1 = 1100
        Reference_Word2 = 1100
        Reference_Word3 = 1100
        MyVar = 0
        IF A = 1 THEN Show_Print
        Return_To_Puch_Button_1:
        A = 0
        WHILE Select_Push_Button = Is_Pressed : GOSUB PAUSE_100 : WEND
        IF MyVar = 0 THEN MAINLOOP
       IF Hours_Push_Button = Is_Pressed then ' #2
        GOSUB Sound_Buzzer : A = 2
        MyWord = %1110111011101110
        Reference_Word  = 1110
        Reference_Word1 = 1110
        Reference_Word2 = 1110
        Reference_Word3 = 1110
        MyVar = 0
        IF A = 2 THEN Show_Print
        Return_To_Puch_Button_2:
        A = 0
        WHILE Hours_Push_Button = Is_Pressed : GOSUB PAUSE_100 : WEND
       IF Minutes_Push_Button = Is_Pressed then ' #3
        GOSUB Sound_Buzzer : A = 3
        MyWord = %1101101111001001
        Reference_Word  = 1101
        Reference_Word1 = 1011
        Reference_Word3 = 1001
        MyVar = 0
        IF A = 3 THEN Show_Print
        Return_To_Puch_Button_3:
        A = 0
        WHILE Minutes_Push_Button = Is_Pressed : GOSUB PAUSE_100 : WEND
       IF Seconds_Push_Button = Is_Pressed then ' #4
        GOSUB Sound_Buzzer : A = 4
        MyWord = %1010100110101001
        Reference_Word1 = 1001
        MyVar = 0
        IF A = 4 THEN Show_Print
        Return_To_Puch_Button_4:
        A = 0
        WHILE Seconds_Push_Button = Is_Pressed : GOSUB PAUSE_100 : WEND
       IF Toggle_Push_Button = Is_Pressed then ' #5
        GOSUB Sound_Buzzer : A = 5
        MyWord = %1111101110101101
        Reference_Word  = 1111
        Reference_Word3 = 1101
        MyVar = 0
        IF A = 5 THEN Show_Print
        Return_To_Puch_Button_5:
        A = 0
        WHILE Toggle_Push_Button = Is_Pressed : GOSUB PAUSE_100 : WEND
     Next MyVar
     GOTO mainloop
    Jan 2006
    Istanbul
    Jessey,
    "There are many ways to skin a cat"; for some "a dog", "a snake", etc...
    Someone writes a code in his/her logic and it works with no problem.
    Someone else writes a different code in a different logic and it also works and does the same job with no problem.
    A third one writes a code in much shorter and faster way, it does the same job and works with no problem, too.
    Now, since you are starting to programming, I suggest you skip the arrays at first and write long lines instead .
    If you start your coding with arrays at the beginning, I see more complexity and confusion in front of you.
    So when it comes to your code and project, there are of course several ways to do the same job in relatively less lines with arrays and some advanced coding techniques.
    But why now?
  1. changing osc on the fly
    By viewgsm in forum mel PIC BASIC Pro
    Last Post: - 6th February 2010, 16:13
  2. Mode changing on the fly
    By Angus Anderson in forum GSM
    Last Post: - 28th November 2006, 09:58
  3. edit names of variables
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 13th January 2005, 22:00
