Controlling MAX7311 port extender
Results 1 to 5 of 5
    Sep 2005
    Default Controlling MAX7311 port extender
    I want to communicate with MAX7311 port extender.
    It has 16 I/O ports. Its uses I2C (max 400 Kbit\s)
    http://datasheets.maxim-ic.com/en/ds/MAX7311.pdf
    The I2C master is PIC16F628A @ 20Mhz with software I2C.
    The job:
    TX: Read out the 1st MAX7311 16input ports, transmit to the receiver side with RS232.
    RX: receive the message with the 2nd, write the 16bits to the 2nd MAX7311 outputs.
    The inteface between the 2 PIC is NOT a problem.
    Just the software interface between PIC-MAX7311.
    There is the TX side on the picture.
    http://kepfeltoltes.eof.hu/files/83_431164563466.png
    The extenders I2C address is: 0x40 (64 dec).
    CLK:PB3, DATA:PB2
    switch VAR byte[2]
    I2Cread PORTB.2,PORTB.3,0,64,switch[0],switch[1]
    'Control=0, Adr=64, store received 2 bytes in switch
    switch VAR byte[2]
    I2Cwrite PORTB.2,PORTB.3,0,64,switch[0],switch[1]
    'Control=0, Adr=64, set
    Is this going to work?
    START, STOP, and acknowledge bits are automatical controlled by I2Cwrite/read command?
    How do I set the 2nd MAX7311's Port1/Port2 registers to output?
    Thank you!
    It's a bit confusing, isn't it?
    The expanders "address" goes in the I2C Control byte, and the "command" goes in the Address byte.
    Read Input Ports:
    I2Cread PORTB.2,PORTB.3,64,0,[switch(0),switch(1)]
    Write Output Ports:
    I2Cwrite PORTB.2,PORTB.3,64,2,[switch(0),switch(1)]
    Set Port Configuration:
    PE_TRIS VAR BYTE[2] ; bitwise - 1=input 0=output
    PE_TRIS(0) = 255    ; Port1 all input
    PE_TRIS(1) = 0      ; Port2 all output
    I2Cwrite PORTB.2,PORTB.3,64,6,[PE_TRIS(0),PE_TRIS(1)]
    For a second Expander, you would tie pin <strike>AD1</strike> AD0 to Vdd to change it's slave address to 66. Then you can use it just like the first one.
    Read Input Ports:
    I2Cread PORTB.2,PORTB.3,66,0,[switch(0),switch(1)]
    Set Port Configuration: (all output)
    I2Cwrite PORTB.2,PORTB.3,66,6,[0,0]
    HTH,
    Last edited by Darrel Taylor; - 26th November 2006 at 23:33. Reason: Fixed AD0 Typo
    Sep 2005
    Thank you very much!!!
    How can MAXIM swap the Control Byte and a Address byte order?
    Isn't that standard?
    If I want the 66 slave address (that is 0x42), I will have to set like this:
    AD2 GND
    AD1 GND
    AD0 Vdd
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by mrx23
    In reality, nothing is "swaped", its just that PBP has chosen to label the bytes in their software I2C in a "non-standard manner". This is because they use the labels used for EEPROMs. (worth looking at a datasheet)
    I2CREAD DataPin,ClockPin,Control,{Address,}[Var{,Var...}]{,Label}
    As listed, Control is the first byte sent. Bit 0 of this byte controls the direction of communication, either a read or write operation. In many I2C devices, the first byte sent, with bit 0 as the R/W bit, is called the slave address (but not with EEPROMs).
    Address is also confusing, since PBP uses this to refer to the internal register address being accessed in the device, not the actual bus address of the device. It will be the byte/word sent after the slave-address/control byte, and is called different things based on the device, but "command-byte" or "control-byte" are common. (but not with EEPROMs)
    You definately need a good understanding of the I2C protocol to translate PBPs I2C commands to a device other than an EEPROM
    AD2 GND
    AD1 GND
    AD0 Vdd
    Yes, it looks that way to me.
    Hope this clears it up a little more,
    Caught me with a typo
    I also want to mention that you shouldn't have the 2 - 1.0K resistors between the two chips.
    All you need are the 2 - 4.7k pull-ups.
  1. Why (or how to) make a port array for OW
    By Roy___ in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2009, 23:30
    Last Post: - 14th November 2008, 17:25
  3. port config.
    By tamertokgoz in forum mel PIC BASIC Pro
    Last Post: - 25th July 2008, 12:25
  5. STATUS re-curtain W
    By zugvogel1 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2005, 15:21
