USART Stops Receiving Characters
Results 1 to 8 of 8
    Jun 2006
    Default USART Stops Receiving Characters
    Im having a problem where the usart sucessfully receives characters for a few seconds, each time sending a response, however inevitably stops receiving characters after a while (Interrupt is not triggered, and RCIF doesn't get set). I have set DEFINE HSER_CLROERR 1. The PIC is connected to the computer via a wireless serial link using an XBee, should the 3.3v serial ouput from this module be cause for concern? If I connect the Tx and Rx lines together I get everything i send echo'd back. There is <5mA ripple on the serial and power supply lines. Any ideas?
    Edit: Might also be worth noting that the PIC continues to run, for instance it can still HSEROUT while not receiving any serial input.
    Edit2: It appears not to stop receiving characters if the oscilloscope probe is connected, does that sound right? It is listed as a 10MOhm, 33pF probe.
    Daniel
    Any scheme to post here?
    PIC #
    Osc Type and speed, crystal
    Jan 2006
    Istanbul
    Quote Originally Posted by mister_e
    PIC #
    It is good to see that it is not only me still using traditional ways, even very ancient ways, to find answers.
    But Steve, may be your CrystalBall have limited data base.
    I use the Genie in the picture and I get anything I ask her!
    The bad thing is that I can only ask three questions per weekend!
    time for a change
    Just ask here to have more than 3/week... it's still a wish
    Jun 2006
    PIC18F2525 running at 20Mhz with a ceramic resonator.
    The Rx line is fed directly from the XBee Tx, Tx (if relevent) goes through a voltage divider to give 3.3v input to the XBee..
    Initialisation:
    DEFINE OSC 20
    ' ---- Setup Hardware for USART ----
    DEFINE HSER_BAUD 9600
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    ' ---- Setup Hardware for ADC ----
    DEFINE ADC_BITS 8 ' Set number of bits in result
    DEFINE ADC_CLOCK 3 ' Set clock source (rc = 3)
    DEFINE ADC_SAMPLEUS 20 ' Set sampling time in microseconds
    INCLUDE "variables.bas" 'Define Variables
    ' ---- Initialisation ----
    Init:
    Pause 10 'Safe Start Up Delay
    ADCON1 = 14 ' All pins are digital, except AN0 (RA0)
    CMCON = 7 ' Turn off comparators
    INTCON2.7 = 1 ' Turn off PORT B pull ups
    'Timer 0 is used for Input Pulse Measurement
    TMR0L = 0 'clear Timer 0 low byte
    T0CON = %11000101 'prescale = /64
    INTCON.5 = 0 'disable TMR0 interrupt
    'Timer 1 is used for the internal game clock
    T1CON.4 = 1
    T1CON.5 = 1 '8 prescaler
    TMR1ON = 0 'Stop the timer, enable once game running
    'Timer 2 is used for HPWM, is it really?
    Init_Ports:
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    PORTA = %00000000
    PORTB = %00000000
    PORTC = %00000000
    Input Rx
    Output Tx
    Input Serial_In
    Input Menu
    Input Battery
    Input Mercury
    'No PWM output when pin is input
    Input Backlight
    HPWM 1,50,40000
    Output Serial_Out
    Low Serial_Out
    Init_Proceedure:
    For i = 0 To 200
    Pause 1
    Next i
    GoSub Update_LED
    GoSub Update_LCD
    HSEROUT ["+"]
    Init_Interrupts:
    RCIE = 1 'Enable USART Rx Interrupt
    TMR1IE = 1 'Enable Timer 1 Interrupt
    INTCON2.6 = 0 'INT0 on Falling Edge
    INTCON = %11010000 'Global, Peripheral, INT0 Enable
    ON Interrupt Goto Interrupt_Handler
    Main_Loop:
    If Menu Then
    Input Backlight
    Else
    Output Backlight
    EndIf
    'Motion, Report If Requested.
    If (Report_Mercury = 1) AND (Status_Mercury <> Mercury) Then
    Report_Mercury = 0
    Status_Mercury = Mercury
    HSEROUT ["F"]
    EndIf
    Goto Main_Loop
    Interrupt:
    ' ---- Interrupts ----
    DISABLE
    Interrupt_Handler:
    If RCIF Then Goto Int_Rx
    If INT0IF Then Goto Int_Hit
    If TMR1IF Then Goto Int_Time
    Interrupt_Exit:
    INT0IF = 0
    While RCIF
    t = RCREG ' trash leftovers to clear RCIF before return
    Wend
    RESUME
    Int_Rx:
    If RCSTA.1 Then
    HSEROUT ["Overrun"]
    Pause 6
    EndIf
    HSERIN 1, Interrupt_Exit, [PacketID, PacketCheckSum, str Buffer\20\Sentinel]
    CheckSum = 0
    If PacketID > 0 Then
    For i = 0 To 20
    CheckSum = CheckSum + Buffer[i]
    Next i
    EndIf
    If (PacketID > 0) AND (PacketCheckSum != (255 - CheckSum)) Then 'Failed To Receive Correctly
    HSEROUT ["\", PacketID]
    Pause 6
    Else
    Select Case Buffer[0]
    'Do Stuff
    End Select
    Pause 6
    HSEROUT ["/", PacketID]
    Pause 6
    EndIf
    Goto Interrupt_Exit
    Feb 2003
    Does it work if you remove the wireless link and have a direct cable connection?
    If not then there is a code problem with the PIC
    If it works then for some reason the radio link is dying.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Default Missing include
    Quote Originally Posted by breesy
    Hi Breezy,
    no one can compile without variables.bas
    JS
  1. Receiving Packet Array In Usart
    By crhomberg in forum mel PIC BASIC Pro
    Last Post: - 24th April 2007, 21:41
  2. Receiving Packet Array In Usart
    By crhomberg in forum Serial
    Last Post: - 18th April 2007, 23:31
  3. I2CRead and USART interrupt
    By HenrikBuhl in forum mel PIC BASIC Pro
    Last Post: - 10th January 2007, 14:04
  4. problem with USART
    By leemin in forum Serial
    Last Post: - 11th December 2006, 18:56
  5. USART Problem Receiving Bytes
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 15th September 2005, 18:50
