pot command
Results 1 to 23 of 23
Thread: pot command
    Sep 2006
    yes thats what I am beginning to realize too , lots of stuff missing in the book, then when you use another chip, I'm screwed.
    Abou tthe A/D, doesn't that read a voltage ? whereas the Pot read a resistance ?
    Sep 2006
    both cde works,
    i am trying to figure out one thing now.
    I am replacing this command line:
    HIGH PORTB.0
    PAUSE 1000
    LOW PORTB.0
    by this one:
    serout 2,n9600,(2)
    i am getting errors:
    C:\PBP\POT_TRY.BAS ERROR Line 39: Bad expression.
    C:\PBP\POT_TRY.BAS ERROR Line 33: ID LED2 is not a LABEL.
    C:\PBP\POT_TRY.BAS ERROR Line 34: ID LED3 is not a LABEL.
    C:\PBP\POT_TRY.BAS ERROR Line 35: ID LED4 is not a LABEL.
    suddenly my labels are not labels ??
    Feb 2003
    Sometimes the error messages bear no relation to the actual error.
    Try changing serout 2,n9600,(2)
    to serout 2,n9600,[2]
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Sep 2006
    yes thanks,
    those french keyboards...
    k
    yeah i know what you mean. It's always handy to have English(United State) driver installed too. Just need to press Shift+Alt to switch between language
    Talking
    Quote Originally Posted by lerameur
    yes thanks,
    k
    For once one can say it's the Keyboard's error ...
    Mhhhh, have something against French Goose liver, Sauternes, Camembert, Cognac, ... and so on ...
    Ahhhh, I see ... that was just a "glitch" ...
    PS: In French, as I've read here, your should be called " Le Ramier " ... and not "Lerameur" ....
    LOL !!!!
    Sep 2006
    wow shift-alt, thats cool.
    I am still confused about one part. The default selection from the compiler is great but very specific for me. Lets say you are using the Pic16F877, with port A, B, C,D,
    I then use the command serout, IS there a problem using the exact port?
    Ex: serout portC.2,N9600,[3]
    instead of 2,N9600,[3] . ( by which I know the pin number, but I dont know the port)
    For me it looks like its taking a random port, obviously , the one by default...
    ken
    Default It's better
    ken
    Hi Ken,
    No it's better to specify PortA or PortB or . . . than just serout 2,N9600. I have only seen serout 2,N9600 used as port B, I think it is a throwback to PBasic and not the pro that still works in Pro,maybe for basic stamps, the PBasic cannot use the Pro sytax which allows you to specify the port. I only use the full name of ports so I do not allow myself to get sloppy, I am not a good enough programmer to ALLOW sloppy, I think generally speaking you can serout on any "I/O" pin which can be made digital, possible exception A.4 or 5 and IT may work with ext. pullup.
    Joe
  1. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 21:31
  2. Using the Pot command.
    By timseven in forum mel PIC BASIC Pro
    Last Post: - 17th August 2009, 21:23
  3. PBP2.50b and POT command problem ?
    Last Post: - 13th October 2008, 18:14
  4. Replies: 4
    Last Post: - 24th January 2007, 23:20
  5. Can I do this???
    By noobie in forum mel PIC BASIC
    Last Post: - 10th June 2006, 19:57
