LCDOUT custom commands - how to?
Results 1 to 40 of 69
    SWITZERLAND (french speaking)
    Default Code
    I'm still not sure how to connect the datalines from the display to the PIC (is it DB0 = D7 and so on or is it DB0 = D4 and so on).
    Here is my code:
    'PIC 16F88
    ' LCD circuitery
    '23,24,25,26,32,33,34,35,40 - Vdd (+5V)
    '27,38  - Vss (GND)
    '28 DB0 - PORTA.0
    '29 DB1 - PORTA.1
    '30 DB2 - PORTA.2
    '31 DB3 - PORTA.3
    '39 RS  - PORTA.4
    '36 E   - PORTA.6
    '37 R/W - PORTA.7
    DEFINE LCD_DREG PORTA       'LCD data port
    DEFINE LCD_DBIT 4           'LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTA      'LCD register select port
    DEFINE LCD_RSBIT 4          'LCD register select bit
    DEFINE LCD_EREG PORTA       'LCD enable port
    DEFINE LCD_EBIT 6           'LCD enable bit
    DEFINE LCD_RWREG PORTA      'LCD read/write port
    DEFINE LCD_RWBIT 7          'LCD read/write bit
    DEFINE LCD_BITS 4           'LCD bus size 4 or 8
    DEFINE LCD_LINES 2          'Number lines on LCD
    DEFINE LCD_COMMANDUS 2000   'Command delay time in us
    DEFINE LCD_DATAUS 50        'Data delay time in us
    ' Register settings
    OSCCON     = %01100000      'Internal RC set to 4MHZ
    ANSEL      = %00000000      'Disable Analogue Inputs
    OPTION_REG = %01000000      'Enable PORTB pullups
    START:
        Lcdout $FE, 1           'Clear screen
    MAIN:
        lcdout $FE, 2,   "This is line one"
        lcdout $FE, $C0, "This is line two"
        goto MAIN
    Roger
    This...
    '28 DB0 - PORTA.0
    '29 DB1 - PORTA.1
    '30 DB2 - PORTA.2
    '31 DB3 - PORTA.3
    is not compatible with this...
    ...and double-check with the Datasheet that you've disabled all Analogue Functions on PortA.
    The display's datasheet makes me connect the lines D4 to DB3, D5 to DB2, D6 to DB1 and D7 to DB0 (see attachment "DB-Lines_connections.jpg"). This is why I thought the starting bit would be the fourth.
    I changed:
    DEFINE LCD_DBIT 0           'LCD data starting bit 0 or 4
    and added:
    ADCON0.0   = 0              'Disable Converter Module
    I went through the PIC's datasheet and couldn't find other settings that could affect the A ports. Still, the display looks just dead.
    I have two of them and react the same. I changed for my second 16F88 and the result is same too.
    Roger
    Feb 2003
    Normally for a 4 bit bus
    DB0-DB3 = D4-D7
    Also if you are using a 16F88 check the ANSEL register
    Keith
    www.diyha.co.uk
    www.kat5.tv
    ANSEL is set to have all analog ports disabled.
    As you suggested, I connected DB0 to D4 and so on...
    Still nothing happens.
    I'm just suprised that the display don't even flickers a little. It looks just like dead. Two displays doing the same makes me think I'm doing something wrong.
    Is is right to say that to make it work the Enable bit must be high? If yes, I could at least mesure it with my logic probe or oscillo....
    What can I "electrically" check else to minimise the cabling error risk?
    Roger
    Feb 2003
    Is there (or should there be) a contrast control that needs adjusting ?
    Keith
    www.diyha.co.uk
    www.kat5.tv
    i'm not sure if PBP handle the R/W line itself.
    How about LOW PORTA.7
    AND maybe i'm blind.. i don't see any config fuses?
    On some LCD, you need to tie the unused DB lines to GND, in your case they should be tied to 5V.
    AND what about the CSB line?
    <img SRC="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1215&d=1164381937">
  1. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 08:56
  2. need help in coding..
    By daphne8888 in forum mel PIC BASIC
    Last Post: - 19th March 2008, 08:31
  3. Help GPS read with serin
    By leinske in forum mel PIC BASIC Pro
    Last Post: - 5th September 2007, 03:33
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 16:04
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
