I have code for a serial to parallel backpack adapter, so yes i send serial commands to the adapter pic. It in turn outputs parallel LCDOUT commands and it works quite well. The code is designed to accept lcdout formatting commands to position each line on the lcd. It stores hserin data in a variable and then outputs into a standard LCD via LCDOUT. NOW in the lcd Defines which affect the PARALLEL LCD configured as a 4 bit display I have installed the following:Originally Posted by keithdoxey
DEFINE LCD_LINES 2. the display seems unaffected when hooked up to a 4 line display, as it continues to correctly display 4 lines of data sent to it. SO THE QUESTION REMAINS, what good is the lines DEFINE if it doesn't limit the output to 2 lines?
JS
