Can defines be changed with port input?
Results 1 to 13 of 13
    Feb 2003
    Quote Originally Posted by Joe S.
    <h4>LCDOUT DEFINES</h4> if LCD_LINES 2 has no apparant effect to limit the LCD from displaying more, why is it even used?
    In the example code you gave you are sending to a Serial LCD display using SEROUT
    LCDOUT DEFINES are exactly what the name suggests...definitions for the LCDOUT command which you are not using!!!
    Likewise HSER_ defines are for HSEROUT and will have no effect on any SEROUT commands.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Default Sorry you are confused
    Quote Originally Posted by keithdoxey
    I have code for a serial to parallel backpack adapter, so yes i send serial commands to the adapter pic. It in turn outputs parallel LCDOUT commands and it works quite well. The code is designed to accept lcdout formatting commands to position each line on the lcd. It stores hserin data in a variable and then outputs into a standard LCD via LCDOUT. NOW in the lcd Defines which affect the PARALLEL LCD configured as a 4 bit display I have installed the following:
    DEFINE LCD_LINES 2. the display seems unaffected when hooked up to a 4 line display, as it continues to correctly display 4 lines of data sent to it. SO THE QUESTION REMAINS, what good is the lines DEFINE if it doesn't limit the output to 2 lines?
    JS
    Wink With PbP You may also have to do something from your own ...
    JS
    Hi,Joe
    Those defines are written for most common types of displays ...
    If using exotic displays ...you also have to verify their commands are those PbP sends when configurating the display ...
    Mhhhh, now, If you DO NOT send data one after the other , but specify WHERE you want it to be written ...
    Only 2 lines will be used ...
    But YOU MUST Tell PbP you USE a 4 LINES Display ... PbP can't think you only WANT 2 lines ... no DEFINE for unwanted lines !!!
    CQFD
    Alain.
    Question Continuing Saga
    Quote Originally Posted by Acetronics
    Hi,Joe
    CQFD
    Alain.
    HI Alain,
    The thing is, if you check post #6, I am sending the data in a manner so as to tell PBP where to write each line, I would expect the software to delimit the display to the addresses available only to a 2 line display if it is defined as a 2 line, even with a 4 line display connected, but it displays all 4 lines. Now if I install a 2 line display, and send 4 lines of data as written in post 6, only the lines written for line 1 and line 2 will display. I would have expected the PIC to truncate the third and fourth lines when set to 2 lines, even when connected to a 4 line display. It appears that is not so. So I still have the question, what effect does DEFINE LCD_LINES have on the LCDOUT command?
    JS
    Feb 2003
    Default Look at the datasheet for the display
    OK. I didnt know what the LCD_LINES define actually did so I took a look in PBPPIC14.LIB and located this section of code.....
        if (LCD_BITS == 8)
          if (LCD_LINES == 1)
            movlw   30h             ; 8-bit mode, 1 line, 5x7 font
            movlw   38h             ; 8-bit mode, 2+ lines, 5x7 font
          if (LCD_LINES == 1)
            movlw   20h             ; 4-bit mode, 1 line, 5x7 font
            movlw   28h             ; 4-bit mode, 2+ lines, 5x7 font
    The "Function Set" register of the 44780 LCD controller chip has the following bits
    D7 = 0
    D6 = 0
    D5 = 1
    D4 = DL
    D3 = N
    D2 = F
    D1 = -
    D0 = -
    where
    DL = DataLength
    1 = 8 bits
    0 = 4 bits
    N = Number of lines
    1 = 2(+) lines
    0 = 1 line
    F = Font
    1 = 5x10 dots
    0 = 5x8 dots
    So looking at the code in the library file, the define is acted upon but is only used to correctly configure the display driver chip for the LCD display connected to it during initialisation.
    When you consider that there isnt a define for LCD_CHARS to declare how many characters are on a line then it follows that it cant do anything clever such as work out that you have reached the end of line 1 and move to the start of line 2.
    PBP does an awful lot of the hard work for you but there are times when you have to take care of some things yourself.
    Keith
    www.diyha.co.uk
    www.kat5.tv
  1. Matrix Keypad routine
    By mister_e in forum Code Examples
    Last Post: - 18th September 2022, 21:30
  2. Input and Output on same Port
    By Frozen001 in forum mel PIC BASIC Pro
    Last Post: - 13th November 2008, 19:46
  3. Accessing Portion of Input Port
    Last Post: - 24th October 2008, 17:33
  5. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 02:50
