Little grammer lesson needed
Results 1 to 5 of 5
    Default Little grammer lesson needed
    Greetings Everybody,
    Minor syntax issue, I wish to place this code in my program, it is 104 charactors long and the page is only 80 charactors. How do I continue a line of assembly code to wrap into the next line?
    @ __config _HS_OSC & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF & _BODEN_OFF & _DATA_CP_OFF
    I RTFM but CFNA (can find no answer)
    thank you again
    Joe
    unfortunatly, you'll have to live with it. I don't remeber there's a way to do it with MPASM __CONFIG... well directly...
    You can Still write the numeric value.. but it's unreadable and a pain to change later
    PBP @ DEVICE allow to use multiple lines.
    Something like this might work
    @MyConfig = _HS_OSC & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _LVP_OFF
    @MyConfig = MyConfig  & _CP_OFF & _BODEN_OFF & _DATA_CP_OFF
    @ __config  MyConfig
    Talking
    That's what i meant by 'I don't remember there's a way to do it with MPASM __CONFIG... well directly... "
    AND YES, i confirm IT'S working... Darrel beat me ... once again
    <img src="http://www.mister-e.org/Pics/RollinEyes.gif">
    Default Coooool
    You Da Man Darrel !
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1213&stc=1&d=116427269 8">
  1. ASCII Viewer Needed
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 19th January 2008, 05:29
  2. Code space needed with MPASM??
    Last Post: - 7th September 2007, 10:24
  3. Programers Needed Still !
    By picawiner in forum mel PIC BASIC Pro
    Last Post: - 5th June 2007, 13:51
  4. Newbee Hardware PWM clarification needed
    By emmett brown in forum General
    Last Post: - 9th July 2006, 09:18
  5. Circuit needed to allow a PIC to turn something on or off
    Last Post: - 12th October 2005, 21:17
