Time interrupt problem
Results 1 to 7 of 7
    DragonBall,
    You have now asked the same question in atleast three different threads and you are not reading the responses you are getting.
    You can not use two ON INTERRUPT statements. You have to, in one SINGLE ISR, determine what caused the interrupt by looking at the different interrupt flags, located in INTCON, PIR1 and PIR2 (For16F87x). If you have TMR0 and TMR1 running and interrupts enabled for both, when the interrupt fires you look at the T0IF and TMR1IF flags to determine which one caused the interrupt.
    I think you are making this more comlicated than it needs to be, IMO you only need one timer interrupt. Look for a suggestion in one of the other threads where you asked this question.
    /Henrik Olsson.
    Nov 2006
    Post
    Hi Henrik Olsson.
    I actually had read all the threads that ppl send to me. I just want to heard ppl's suggestion. If I know that the multiple interrupt will make me complicated then I will heard to your advice.
    I really appreciated all the ppl's reply.
    one thing is i have success doing the LCD diplays.
    Thank to your reply again.
    Please advice me and guide me if i have problem thanks.
  1. INT interrupt problem
    By netstranger.nz in forum General
    Last Post: - 13th October 2009, 07:52
  2. Instant interrupt problem (very strange)
    By yusoweird in forum General
    Last Post: - 31st October 2006, 16:15
  3. Time Interrupt problem
    Last Post: - 24th February 2006, 23:49
  4. Interrupt?? problem
    By scorpion in forum mel PIC BASIC Pro
    Last Post: - 15th July 2005, 04:14
  5. Interrupt and Time Out
    Last Post: - 16th March 2005, 01:10
