Time interrupt problem
Results 1 to 7 of 7
Threaded View
    May 2005
    Default Time interrupt problem
    I got problem with time interrupt not work ....
    How have known rule of time interrupt function pls advise, due to we found probble after we add more code on interrut sub and program will not work after run, But can done complier with out error.
    here sample working :Portb.5 will flash after run.
    OPTION_REG = $57 '57 Set TMR0 configuration
    INTCON = $A0 ' Enable TMR0 interrupts
    ON INTERRUPT GOTO INT
    TMR0 = 0
    Gosub check_Lstatus
    Strobe = 1'strobe off
    latch = 1'lactch off
    clock = 1'CLOCK OFF ACTIVE HIGH
    Sin3 = 0
    Sin2 = 0
    SIN1 = 0
    goto loop
    disable
    INT:
    INTCON.2 = 0
    TMR0 = 0
    'HSEROUT ["n1 ",dec n,13,10]
    TOGGLE PORTB.5
    resume
    enable
    But not work if we add some more code below to replace or below " toggle portb.5"
    disable
    INT:
    INTCON.2 = 0
    TMR0 = 0
    TOGGLE PORTB.5
    FOR K = 0 TO 2
    READ (FONT1+K),COLUM2
    READ (FONT2+K),COLUM0
    READ (SCANROW0+K),ROW0
    GOSUB SCANDATASIN8BITLOWBYTE
    READ (FONT0+K),COLUM3
    READ (FONT1+K),COLUM1
    READ (SCANROW1+K),ROW1
    GOSUB SCANDATASIN8BITHIGHBYTE
    LATCH = 0
    LATCH = 1
    STROBE = 0
    STROBE = 1
    next k
    FOR K = 8 TO 10
    LATCH = 0
    LATCH = 1
    STROBE = 0
    STROBE = 1
    NEXT K
    resume
    enable
    Who have pls advise too .. thank you
    Pls see full code on attached file.
  1. INT interrupt problem
    By netstranger.nz in forum General
    Last Post: - 13th October 2009, 08:52
  2. Instant interrupt problem (very strange)
    By yusoweird in forum General
    Last Post: - 31st October 2006, 17:15
  3. Time Interrupt problem
    Last Post: - 25th February 2006, 00:49
  4. Interrupt?? problem
    By scorpion in forum mel PIC BASIC Pro
    Last Post: - 15th July 2005, 05:14
  5. Interrupt and Time Out
    Last Post: - 16th March 2005, 02:10
