Time interrupt problem
Results 1 to 7 of 7
    May 2005
    Default Time interrupt problem
    I got problem with time interrupt not work ....
    How have known rule of time interrupt function pls advise, due to we found probble after we add more code on interrut sub and program will not work after run, But can done complier with out error.
    here sample working :Portb.5 will flash after run.
    OPTION_REG = $57 '57 Set TMR0 configuration
    INTCON = $A0 ' Enable TMR0 interrupts
    ON INTERRUPT GOTO INT
    TMR0 = 0
    Gosub check_Lstatus
    Strobe = 1'strobe off
    latch = 1'lactch off
    clock = 1'CLOCK OFF ACTIVE HIGH
    Sin3 = 0
    Sin2 = 0
    SIN1 = 0
    goto loop
    disable
    INT:
    INTCON.2 = 0
    TMR0 = 0
    'HSEROUT ["n1 ",dec n,13,10]
    TOGGLE PORTB.5
    resume
    enable
    But not work if we add some more code below to replace or below " toggle portb.5"
    disable
    INT:
    INTCON.2 = 0
    TMR0 = 0
    TOGGLE PORTB.5
    FOR K = 0 TO 2
    READ (FONT1+K),COLUM2
    READ (FONT2+K),COLUM0
    READ (SCANROW0+K),ROW0
    GOSUB SCANDATASIN8BITLOWBYTE
    READ (FONT0+K),COLUM3
    READ (FONT1+K),COLUM1
    READ (SCANROW1+K),ROW1
    GOSUB SCANDATASIN8BITHIGHBYTE
    LATCH = 0
    LATCH = 1
    STROBE = 0
    STROBE = 1
    next k
    FOR K = 8 TO 10
    LATCH = 0
    LATCH = 1
    STROBE = 0
    STROBE = 1
    NEXT K
    resume
    enable
    Who have pls advise too .. thank you
    Pls see full code on attached file.
    It doesn't work because you are using GOSUBs inside your interrupt handler,
    and jumping into routines outside the disable/enable block.
    PBP is inserting interrupt checking code in the sub-routines you enter with
    these GOSUBs. Once you jump outside the disable/enable block, you land on
    code testing for the interrupt condition, and program execution returns to
    the entry point of your interrupt handler.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Nov 2006
    Post tmr0 and tmr1
    Hi all
    Can we use 2 interrupt at the same time?
    (i)TMR1 act as sending pulse 4.32 second to the driver.
    (ii)TMR0 act as 1 second elapsed to create time and date.
    Please advice
    Yes you can do it, you can use ALL PIC interrupts at the time. In the ISR you need to track it down. Bear in mind to keep your ISR as short as possible.
    Nov 2006
    Post Help.Please advice
    Hi
    Thank to the advice.
    *************ISR you need to track it down????******************
    Below are the basic program:-
    Is that what you mean????
    ' Initialization of TMR0 and TMR1
    ON INTERRUPT clockpulse
    ON INTERRUPT elapsed time
    'some coding here
    DISABLE
    clockpulse:
    'some coding here
    RESUME
    DISABLE
    elapsed time:
    IF tick<16 then
    tick = 0
    bs = bs + 1
    'some coding here
    ' reset tmr0 flag
    RESUME
    Please advice thank
    DragonBall,
    You have now asked the same question in atleast three different threads and you are not reading the responses you are getting.
    You can not use two ON INTERRUPT statements. You have to, in one SINGLE ISR, determine what caused the interrupt by looking at the different interrupt flags, located in INTCON, PIR1 and PIR2 (For16F87x). If you have TMR0 and TMR1 running and interrupts enabled for both, when the interrupt fires you look at the T0IF and TMR1IF flags to determine which one caused the interrupt.
    I think you are making this more comlicated than it needs to be, IMO you only need one timer interrupt. Look for a suggestion in one of the other threads where you asked this question.
    /Henrik Olsson.
  1. INT interrupt problem
    By netstranger.nz in forum General
    Last Post: - 13th October 2009, 07:52
  2. Instant interrupt problem (very strange)
    By yusoweird in forum General
    Last Post: - 31st October 2006, 16:15
  3. Time Interrupt problem
    Last Post: - 24th February 2006, 23:49
  4. Interrupt?? problem
    By scorpion in forum mel PIC BASIC Pro
    Last Post: - 15th July 2005, 04:14
  5. Interrupt and Time Out
    Last Post: - 16th March 2005, 01:10
