Help with CC1100 RF Modules.
Results 1 to 14 of 14
    Sep 2003
    Vermont
    Next thing to do is to set the registers for continuous transmit of random characters. See if you get an output from the transmitter. At this point, don't worry about what comes out, just that something does. Next, I have smoked a number of cc1100s with only a slight overvoltage pulse. Is it possible to jumper the mfg board processor output to the CC1100 input? This will test the CC1100 in circuit and see if it is operating.I did this with the development kit and saved mucho time.
    that's all for now,
    Ron
    Sep 2003
    INDIA
    Default Thank you very much.
    Hello Ron,
    Thanks a millon for coming to my rescue. Well a few things I need to understand is what is the sequence to transmit a particular byte thru these modules and What is the sequence to set the Module in receive mode. As you said , there is a lot of grey area in the datasheet , which only explains on how to program the registers. Well I have successfully been able to program the registers and all that what is said on the top.
    OK some inputs to your suggestion. I have been able to transmit some 15 bytes using the method I explained in my previous thread and for sure , I have monitored these signal on my R1 Scanner Receiver.
    How do I
    1. Program the registers for continous transmisson.
    2. How do I program the PA_Table. Is it necessary.
    3. In the abscence of GD0 and GD1 Pins How do I provide an interupt to the MCU for a received packet in the buffer.
    I have many more question to ask, but I just don't want to bother you on that.
    regards
    p.s. I have the Code for the Manufacturer's demo Board in "C" but don't understand Head "NOR" Tail from it. If it helps you , I can send it to you. I just understood that the manufacturer sends the packet at different PA level for possibility that the module is just to near to each other and likewise. More on this later.
    Sep 2003
    Vermont
    How do I
    If you want to send the data as a packet, it is difficult at best. It's similar to filling up a bucket with water and when it gets to a preset level, the bottom drops out to empty it. The only difference is that it adds a CRC at the end. You can turn it into a transparent transmitter that will just send out anything you put into it, but you lose a lot of good reasons to use the CC1100 in the first place.
    The PA table is for power ramping in OOK or ASK. I guess it is useable in very restrictive areas for spurious reductions. Only the first address is used for normal use. Just input the value on page37 for the power level you choose.
    Set FREND0.PA_POWER to 0 to choose the first register. PATABLE is $3E.
    RXFIFO is 3F + $80. This is one of those gotchas. Get the transmitter working before you pull any hair out over receive. When you get a chirp, move on.
    I believe GDO1 is presented as SO to you. When CS goes high, it becomes a general output. If you change the register data to $07, it will go high when a valid packet is received.
    Sep 2003
    INDIA
    Default Inputs
    Hello Ron,
    1. I tried your suggestion and i do get a chirp on my Receiver.
    2. I don't understand what you meant by RXFIFO is 3F + $80. Does this mean that I have to look for data @ $BF. I tried to access it but no reply.
    3. I changed PA_Table to C6 i.e. 8.7 dbm out put. You referred to page 37 but i found it on pg 49. I hope its the same.
    4. OK one thing i wanted to tell you is that I can access the 31.3 Status Registers mentioned on page 81 with the addresses mention in the brackets. eg. RSSI I can access it @ F4 and not $34 likewise. Is this normal or something Wierd.
    5. What is the procedure to Transmit and receive?. OK I shall tell you what I do. I go to idle mode. Flush out TX_Buffer. I fill the TX_BUFFER with 3 Bytes. Then enable TX and check the Tx_buffer. OK the buffer empties , so I presume that the data is flushed out.
    6. Register values of my setup are
    CC_Addr = _IOCFG2 : Reg_WR = $2E
    CC_Addr = _IOCFG1 : Reg_WR = $07
    CC_Addr = _IOCFG0 : Reg_WR = $06
    CC_Addr = _FIFOTHR : Reg_WR = $07
    CC_Addr = _SYNC1 : Reg_WR = $D3
    CC_Addr = _SYNC0 : Reg_WR = $91
    CC_Addr = _PKTLEN : Reg_WR = $FF
    CC_Addr = _PKTCTRL1 : Reg_WR = $0E
    CC_Addr = _PKTCTRL0 : Reg_WR = $05
    CC_Addr = _ADDR : Reg_WR = $01
    CC_Addr = _CHANNR : Reg_WR = $00
    CC_Addr = _FSCTRL1 : Reg_WR = $06
    CC_Addr = _FSCTRL0 : Reg_WR = $00
    CC_Addr = _FREQ2 : Reg_WR = $0C
    CC_Addr = _FREQ1 : Reg_WR = $1D
    CC_Addr = _FREQ0 : Reg_WR = $89
    CC_Addr = _MDMCFG4 : Reg_WR = $C7
    CC_Addr = _MDMCFG3 : Reg_WR = $83
    CC_Addr = _MDMCFG2 : Reg_WR = $03
    CC_Addr = _MDMCFG1 : Reg_WR = $A2
    CC_Addr = _MDMCFG0 : Reg_WR = $F8
    CC_Addr = _DEVIATN : Reg_WR = $40
    CC_Addr = _MCSM2 : Reg_WR = $07
    CC_Addr = _MCSM1 : Reg_WR = $30
    CC_Addr = _MCSM0 : Reg_WR = $18
    CC_Addr = _FOCCFG : Reg_WR = $16
    CC_Addr = _BSCFG : Reg_WR = $6C
    CC_Addr = _AGCCTRL2 : Reg_WR = $43
    CC_Addr = _AGCCTRL1 : Reg_WR = $40
    CC_Addr = _AGCCTRL0 : Reg_WR = $91
    CC_Addr = _WOREVT1 : Reg_WR = $87
    CC_Addr = _WOREVT0 : Reg_WR = $6B
    CC_Addr = _WORCTRL : Reg_WR = $F8
    CC_Addr = _FREND1 : Reg_WR = $56
    CC_Addr = _FREND0 : Reg_WR = $10
    CC_Addr = _FSCAL3 : Reg_WR = $E9
    CC_Addr = _FSCAL2 : Reg_WR = $0A
    CC_Addr = _FSCAL1 : Reg_WR = $00
    CC_Addr = _FSCAL0 : Reg_WR = $1F
    CC_Addr = _RCCTRL1 : Reg_WR = $41
    CC_Addr = _RCCTRL0 : Reg_WR = $00
    CC_Addr = _FSTEST : Reg_WR = $59
    CC_Addr = _PTEST : Reg_WR = $7F
    CC_Addr = _AGCTEST : Reg_WR = $3F
    CC_Addr = _TEST2 : Reg_WR = $81
    CC_Addr = _TEST1 : Reg_WR = $35
    CC_Addr = _TEST0 : Reg_WR = $09
    CC_Addr = _PATABLE : Reg_WR = $C6
    7. Any simple code that I can try to test the communication. The modules are working as after each couple of test i test it on the Manufacturer's demo board.
    8. I have the code for the Manufacturer's demo board written in C. If that could help ? I personally don't undrestand C.
    9. Am I right in checking the status byte on the receiver board for received data. I presume apart from showing that the module is in Rx mode it will also tell me of the number of bytes it would have Rx. or is there any other way.
    Sep 2003
    INDIA
    Default Shiftin / Shiftout giving problem
    Ron,
    I am having problems with some of the routines using Shiftin / Shiftout.
    You mentioned in your earlier thread to use a couple of (5) nop using asm. can you please give an example.
    I am having some problem issuing a strobe signal using Shiftin/out and reading the status register. presumeably it should be the timing problem.
    Otherwise the register read/write work perfectly. Even the Multi Read/Write works great.
    Just one querry. What should be the addr value when you enter the read_stat routine.
    thank you.
    Sep 2003
    INDIA
    Default Finally Got them to Work, But there's a problem
    Ron,
    I finally got the modules to transmit and receive some data in the RX_BUFFER at the other end , but there is a problem.
    If I transmit 3 Bytes , I get 6 Bytes in the Rx_Buffer which do not tally, but are consistent and not random.
    Can you help. A PM helps you understand it much better.
    regards
    Sep 2003
    Vermont
    The receiver adds a CRC and RSSI info to the packet. Read the bytes out and see if your data is in the packet.
  1. RF Modules
    By tonyfelloni in forum mel PIC BASIC Pro
    Last Post: - 26th June 2010, 18:42
  2. RF Modules (Zigbee)
    By Chris Barron in forum mel PIC BASIC Pro
    Last Post: - 4th March 2010, 19:28
  3. Low latency Wireless RF transceiver modules?
    By mark155 in forum General
    Last Post: - 4th March 2010, 06:20
  4. RF Transceiver modules help
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 16th May 2008, 15:54
  5. RF Modules at 433.92MHz
    By Ioannis in forum Adverts
    Last Post: - 17th October 2006, 13:36
