Help with CC1100 RF Modules.
Results 1 to 14 of 14
Threaded View
    Sep 2003
    INDIA
    Default Help with CC1100 RF Modules.
    I am experimenting with the CC1100 (clone) RF modules and find myself stuck in the middle of nowwhere. I have a pair of Demo Boards from the manufacturer on which these modules work perfectly and on all frequencies so it rules out the possibility of the Modules not working. I have had major help from Ron Marcus and Joe Desimone who shared their code with me for a jumpstart.
    Solution:
    I have a demo board of my own made for a 28 Pin PIC MCU (16F876A @ 4Mhz ) with 4 tactile switches, 4 LED's, and LCD (which I don't use) and a RS232 IO. I am just interested in sending a ASCII character from one Board to the other , at the press of a switch. Actual configuaration of portpins is given in the code. I prefer to use 315 Mhz as I have a old IC-R1 Communication receiver (my test equipment) to monitor the frequency for Transmission. On the manufacturer's demoboard i get a clean chirp of data transmission.
    The RF modules that I have , have 5 pins for control, viz: TE (enables PA on Board), CSn, SO,SI and SCLK operating on 5V..
    Problem:
    It just does not Transmit, and the receiver just does not Receive. The reason I tell this is because , I tried transmitting some data from the manufacturer's Demo Board on that frequency and try to monitor the Rx FIFO on my board for any data. I cannot transmit because , i monitor for some Data on my IC-R1 and nothing copied. I am surely doing something worng somewhere. But I can program, verify the registers on the module perfectly. I can also see that Data goes into the TX_FIFO and (hopefully) Flushes out when I enable the TX. I check the TE going High during Tx the same way it happens on the Manufacturer's Demo Board, so no chance of getting that wrong (Active High/Low)
    There are just a few doubts regarding :
    - Register values. These values fairly tally with the values I derived from Smart RF studio for the frequency.
    - Transmit and Receive Sequence. Can someone please tell me the Receive and Transmit sequence with these modules.
    I attach various codes I tried to this thread for some one to help me.
    I once again , sincerely, thank Ron Marcus and Joe Desimone for their help with their code, and look forward to their help once more.
    regards
  1. RF Modules
    By tonyfelloni in forum mel PIC BASIC Pro
    Last Post: - 26th June 2010, 18:42
  2. RF Modules (Zigbee)
    By Chris Barron in forum mel PIC BASIC Pro
    Last Post: - 4th March 2010, 19:28
  3. Low latency Wireless RF transceiver modules?
    By mark155 in forum General
    Last Post: - 4th March 2010, 06:20
  4. RF Transceiver modules help
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 16th May 2008, 15:54
  5. RF Modules at 433.92MHz
    By Ioannis in forum Adverts
    Last Post: - 17th October 2006, 13:36
