dim a led
Results 1 to 4 of 4
Thread: dim a led
    Jan 2006
    Default dim a led
    hello, I would like dim 2 leds with a 16f628 and I wanted to know which function to use but if I use the function pwm the program is very slow
    regards
    fred
    Oct 2003
    holland
    Then you may try the Hpwm function (only one) or write your own pwm that is faster then.
    Jan 2006
    thanks
    how one can create his pwm?
    fred
    Oct 2003
    holland
    pwmxl:
               if cntr = 0 then outputport = 1        'this clears all pwm ports
               if cntr = dutycl then outputport = 0  'this line can be repeated for as
        'many as you have pwm outputs
               cntr = cntr + 1
               if cntr = 0 then exitpwm
               goto pwmxl
    exitpwm:
    I hope the rest you figger out by yourselfs !
  1. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  2. For next loop using: Led var Byte
    By quester in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 11:16
  3. LCD will not start
  4. Interrupts interfering with PRINT
    By lsteele in forum General
    Last Post: - 21st September 2006, 21:44
  5. can't even flash an LED
    By bruno333 in forum mel PIC BASIC Pro
    Last Post: - 28th April 2005, 14:27
