Turn OFF Sound command
Results 1 to 6 of 6
    Gator_sound's Avatar
    Gator_sound Guest
    Talking
    Sayzer,
    I got it to stop going off. I just put the frequency to 0.
    For example, SOUND PORTB.1, [0,5]
    Than go where ever I need to go. Thanks Sayzer for inquiring about my problem. Feel bad I didn't figure it out in the first place.
    Jan 2006
    Istanbul
    I am not sure how your code is designed to work; may be you just added an example to show the idea here.
    I modified your code a little bit as below. May be it is similar to what you need.
    INCLUDE "MODEDEFS.BAS"
    OSCCON = %01100110  'Set for 4Mhz, but need to check the rest!
    TRISA =  %00000000  'All outputs.
    TRISB =  %00010100
    'PORTB.2 'START BUTTON
    'PORTB.4 'STOP BUTTON
    'PORTB.0 'LED
    'PORTB.1 'PIEZZO
    ADCON1 = %11111111   'All digital
    '===========Variables & Hardware assignment=============
    ALM_Flag  var bit     'Alarm status
    LED       VAR PORTB.0 'Pin for LED
    PIEZZO    var PORTB.1 'Pin for Piezzo
    Start_BTN VAR PORTB.2 'Pin for Start Button
    Stop_BTN  VAR PORTB.4 'Pin for Stop Button
    '==========Initial Settings=============================
    low LED
    LOW PIEZZO
    ALM_Flag = 0
    Start:
       IF Start_BTN = 0 THEN
          WHILE Start_BTN = 0 : WEND   'Wait for finger release!
          ALM_Flag = 1                 'Turns the alarm flag ON once.
       IF Stop_BTN = 0 Then
          WHILE Stop_BTN = 0 : WEND   'Wait for finger release!
             ALM_Flag = 0             'Turns the alarm flag OFF once.
       IF ALM_Flag = 1 then
          Sound PIEZZO, [1,255] 'Run Sound Command
          'Depending on the piezzo type you have, you can just use HIGH and LOW commands.
          'Example: HIGH PIEZZO  'This will run the piezzo until you LOW the Piezzo pin.
          HIGH LED              'LED indicates that Alarm is ON. Or do you want this to Flash?
          LOW PIEZZO    'Stop sounding.
          LOW  LED      'Alarm is OFF.
    GoTo Start
    There are couple of things to pay attention.
    1. Exactly when do you need to TOGGLE the LED?
    2. Are buttons pressed by a user? If yes, "WHILE" will help you to wait for finger release. Check the example.
    3. Check your piezzo type. You may just use HIGH and LOW commands to drive it. Thus, couple of lines will be good enough for your code.
    Gator_sound Guest
    Smile
    sayzer,
    The LEDs are there to indicate that the code went into the sub routine or through the loop. I tried driving the piezo though with the high and low command but it did nothing. Its why I resorted to asking the forum. I think I'll use the while statement though. I was just testing out the different components of my project with respect to their code. I'm doing an alarm clock with some RF technology integrated. I used LEDs to check if they my code was working properly as a way of debugging. I understand its not the most efficient way of doing things but it worked well with small parts of my code.
    Thanks for taking the time to revise and update my code. I'll look more into it some more in a bit. I appreciate it.
  1. Help w/ speaker for 16F690 and SOUND command
    By bhiggenson in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2009, 18:55
  2. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
  3. LCD will not start
  4. Can I do this???
    By noobie in forum mel PIC BASIC
    Last Post: - 10th June 2006, 18:57
  5. Re: quick fix for sound command?
    Last Post: - 9th July 2004, 01:44
