how to send ports high
Results 1 to 5 of 5
    Jun 2006
    Default how to send ports high
    i have just started to use the 16c63a pic can you use the high comand to send pins on port b and port c to out put and iff so what dose the code look like
    i am using microcode studio as the text editor and pbp for the compiler
    any help much apricated
    I hate to say this but have you looked up High in the PBP manual or in the MCS help? It tells you everything you need to know. If not - please explain what is and someone will jump in and help you.
    /Henrik Olsson.
    Jan 2006
    Istanbul
    andrew,
    Do you want to make all pins of a port HIGH or LOW at the same time?
    Was that the question?
    High and LOW for individual PINs
    High PORTA.0
    ALL PORT pins?
    TRISB=0
    PORTB=%11111111 ' all PINs to 1
    Jun 2006
    Smile thanks for help
    thanks all
    it is for an led display
    i found that
    high portc.0
    low portc.0
    works
    thanks
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 20:08
  3. Old and beyond help ?
    Last Post: - 11th December 2008, 15:23
  5. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 02:37
