MAX1247 4-Channel, 12-Bit ADC
Results 1 to 15 of 15
    I would tend to believe the problem is with the power supply.
    Or more specificaly, the measurement of the power supply's voltage.
    A simple test is to use a voltage that you don't need to "read" to know what it is. And the easiest way to do that is with a simple voltage divider.
    With 2 resistors 100k to Vdd(+5V) and 220 ohms to Vss. you will get approximately 11mv at the junction. Of course it depends on the tolerance of the resistors you use, but it will still be very close even with 5%.
    With 12 bits and 2.5Vref, that should give an A/D value of 22, and due to integer truncating should read 10 mv after the *6/10.
    So if it reads 10mv, then the problem is the difference between the actual power supply voltage and the external measuement of that voltage.
    Sep 2006
    Florida, USA
    Smile
    Darrell - Thanks for your suggestion... Although I was verifying the voltage being output with another meter, I will give it a try (I'll try anything right about now) and let you know what happens.
    Atom058
  1. MCP3208 12 bit A/D driver
    By polymer52 in forum Code Examples
    Last Post: - 5th February 2010, 12:59
  2. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
  3. Flash PIC with 12 bit ADC
    By Steve_88 in forum mel PIC BASIC Pro
    Last Post: - 12th October 2007, 21:35
  5. Real Time Clock & Eeprom
    By smart_storm in forum General
    Last Post: - 17th February 2006, 20:03
