try..
Code:ReadADC: 'Send Control Byte low CSpin 'cs going low starts the conversion process shiftout doutpin, clkpin, 1, [cb\8] 'Read Adc shiftin dinpin, clkpin, 0, [adresult\12] high cspin return
try..
Steve - Thanks for your reply (again). Unfortunately, the suggestion did not work. I have attached my board layout. It is pretty straight forward - Do you see anything I am missing? Ignore the other chip - it is a 12-bit D-A chip that works fine... Just can't get the input side of this to work. You will see that I have a pot supplying a voltage to CH0 of the MAX1247. I am trying to read this and display the result on the LCD.
Thanks!
First observation, you have to disable ADCs on PORTA
ADCON1=7
and at the top, you should insert a short PAUSE (let's say 50) after
CSpin = 1
Just for safety sake
sorry i'm too lazy tonight to check the whole thing
Fortunately, someone else may have a deeper look to?
Steve - I was really hoping that the ADCON1 thing was it as I missed that one, but still no go. I did the 50 mS pause you recommended, too.
I can't help but think this is one of those "can't see the forest through the trees" thing. I'm sure it's staring me right in the face. I am using a 12 bit D/A (4-channel) chip (MAX525) on this board as well and it works perfectly. Can't imagine why the A/D chip is giving me such a hard time...
Let me know if you think of anything else! Thanks!
This is out of the data sheet for the MAX1247:
"the simplest software interface requires only
three 8-bit transfers to perform a conversion (one 8-bit
transfer to configure the ADC, and two more 8-bit transfers
to clock out the 12-bit conversion result)."
"Simple Software Interface
Make sure the CPU’s serial interface runs in master
mode so the CPU generates the serial clock. Choose a
clock frequency from 100kHz to 2MHz.
1) Set up the control byte for external clock mode and call it TB1. TB1 should be of the format: 1XXXXX11 binary, where the Xs denote the particular channel and conversion mode selected.
2) Use a general-purpose I/O line on the CPU to pull CS low.
3) Transmit TB1 and, simultaneously, receive a byte and call it RB1. Ignore RB1.
4) Transmit a byte of all zeros ($00 hex) and, simultaneously, receive byte RB2.
5) Transmit a byte of all zeros ($00 hex) and, simultaneously, receive byte RB3.
6) Pull CS high.
Figure 5 shows the timing for this sequence. Bytes RB2
and RB3 contain the result of the conversion, padded
with one leading zero and three trailing zeros. The total
conversion time is a function of the serial-clock frequency
and the amount of idle time between 8-bit
transfers. To avoid excessive T/H droop, make sure the
total conversion time does not exceed 120μs."
This seems to be telling me that I have to shift out 3 bytes (control, $00, $00) and I read back 3 bytes - the result is contained in the 2nd two bytes. It also mentions choosing a clock frequency of 100kHz to 2MHz. How do I do that?
I made a stab at the three out, three in routine but no result:
ReadADC:
low CSpin
shiftout doutpin, clkpin, 1, [cb] 'Send Control Byte
shiftin dinpin, clkpin, 0, [rb1] 'Read RB1 in and discard
shiftout doutpin, clkpin, 1, [$00] 'Send a byte of zeros
shiftin dinpin, clkpin, 0, [rb2] 'Read RB2
shiftin dinpin, clkpin, 0, [rb3] 'Read RB3 - RB2&3 contain result
high cspin
Am I using the right modes for shiftin and out?
