PIC18F442-LCD problems
Results 1 to 4 of 4
    Quote Originally Posted by Samoele
    I made circuit with PIC16F876 and used following definitions:
    DEFINE osc 4
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 2
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    LCD is working proper.
    After this I changed MCU, instead of PIC16F876 I put PIC18F442 and changed DEFINE osc 20 and made configuration HS mode on oscillator.
    In program it was also used INT0 PIN on port B.
    LCD does not display anything, all other subprograms are working correct. Do I have to change any register on port B? Does somebody know what is the problem or why this problem occur?
    Thank you for your help.
    Kind regards.
    Samo
    If I understand correctly you have port B set as inputs, they must be set as outputs for the LCD to work. TRISB = %00000000 or if you need to use the leftover bits as inputs then TRISB = %00000011
    JS
    is LVP fuse is set to OFF too?
    Before programming your PIC, make sure your device programmer program those fuses settings.
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. problems with parallel LCD
    By Brown in forum mel PIC BASIC
    Last Post: - 12th June 2008, 05:37
  5. LCD will not start
