Measuring voltage
Results 1 to 9 of 9
    Mar 2005
    Iowa, USA
    Without A/D you can try POT or RCTIME commands, but your better off going with a pic with A/D functionality. Probably cheaper than your PIC16F84A! Another option is an external A/D chip.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Nov 2006
    Quote Originally Posted by rhino
    I have been using the pot command, but it is very erratic. BTW, I'm only using the 16F84A because I had it laying around from my mechatronics class in college. Thanks for all the help.
    i have those laying on my Pin Board
    It's also a good Staple replacement!
    champion, what are the values you are using for the pot as well as the capacitor when using the POT circuit?
    Nov 2006
    I am using a 10k pot with a 0.1uF cap. Its a poly capacitor too. And a 5V regulator.
    champion, The values you are using look good and as long as you are not tying one end of the pot then you should be good to go. Does the pot you are using have any dead spots? I would check it with an ohmeter and verify it doesn't.
    You may have to scale your POT command... for 10K and 100nF try...
    POT Potpin,95,MyVar
    The above is usually good for the same junk Y5 type 100nF Capacitors I sprinkle around for decoupling.
    Talking POT ... to the Waste box
    Hi, Champion
    DO NOT use POT for quite precise measurements ... doesn't worth ANYTHING.
    ( Just good to make a 2 Wires 16 Keys Keypad ... or 16 positions switch !!! )
    The first bearable approach for measuring is to use RCTime, but you WON'T measure 0 - 5v
    Only 1.5v - 5v ... due to the Pic Inputs.
    With cap tied to Vcc and R tied to ground, you should have ~ T = 1.2*R*C ... !!!
    Think to let enough time for the capacitor to be fully charged before measuring ...
    If really precise measure ... think to ADC 831 ... or easier, 16F684,688,819 or ...16F88
  1. Measuring voltage
    Last Post: - 15th July 2008, 14:36
  2. Measuring voltage from a current transformer
    Last Post: - 5th May 2008, 21:19
  3. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 20:35
  4. Measuring Battery voltage
    Last Post: - 3rd December 2006, 23:07
  5. measuring input voltage
    By thon in forum mel PIC BASIC Pro
    Last Post: - 11th August 2004, 16:03
