How to set interrupt for Timer 0
Results 1 to 9 of 9
    NAP uses SLEEP which stops the clock, which stops the timer.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Red face
    DOH! Seems i miss that line
    May 2005
    So , I did change to used ..
    While 1
    wend
    But still same problem found, Who did have sample of time interrupt TMR0 pls share for me too
    May 2005
    Hi what i am worng why i cannot to simulate or debug on this file
    DEFINE LOADER_USED 1
    '@ Device pic16F877, XT_OSC, BOD_OFF, PWRT_ON, WDT_off, PROTECT_OFF,WRT_On
    INCLUDE "modedefs.bas"
    Strobe Var Porta.0
    Latch var Porta.1
    Clock Var Porta.2
    Sin3 var Porta.3
    Sin2 var Porta.4
    Sin1 var Porta.5
    Datasin3 var word
    Datasin2 var word
    Datasin1 var word
    Scanrow1 con 0
    Scanrow0 con 17
    font0 CON 40
    font1 CON 57
    font2 CON 74
    font3 CON 91
    COLUM3 VAR BYTE
    COLUM2 VAR BYTE
    COLUM1 VAR BYTE
    COLUM0 VAR BYTE
    ROW1 VAR BYTE
    ROW0 VAR BYTE
    font0X VAR BYTE
    font1X VAR BYTE
    font2X VAR BYTE
    font3X VAR BYTE
    S1 var bit
    S2 var Bit
    S3 Var bit
    I var byte
    'J Var BYTE
    K VAR BYTE
    'L VAR BYTE
    'N VAR BYTE
    X var byte
    Z var Byte
    'Pause 500
    Trisb = %11111111
    Trisa = %00000000
    ADCON1 = 7
    OPTION_REG = $55 ' Set TMR0 configuration and enable PORTB pullups
    INTCON = $a0 ' Enable TMR0 interrupts
    TMR0 = 0
    'START PROGRAM
    on interrupt goto int1
    Strobe = 1'strobe off
    latch = 1'lactch off
    clock = 1'CLOCK OFF ACTIVE HIGH
    Sin3 = 0
    Sin2 = 0
    SIN1 = 0
    WHILE 1
    WEND
    EEPROM scanrow1,[0,0,0,0,0,0,0,0,1,2,4,8,16,32,64,128]
    EEPROM Scanrow0,[1,2,4,8,16,32,64,128,0,0,0,0,0,0,0,0]
    EEPROM FONT0,[$00,$00,$00,$00,$00,$7C,$40,$40,$78,$40,$40,$7C,$0 0,$00,$00,$00]
    EEPROM FONT1,[$00,$00,$00,$00,$00,$7C,$10,$10,$10,$10,$10,$10,$0 0,$00,$00,$00]
    EEPROM FONT2,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0 0,$00,$00,$00]
    DISABLE
    int1:
    T0IF = 0 'clear the interrupt flag
    TMR0 = 223
    STROBE = 1
    FOR K = 0 TO 8
    READ (FONT1+K),COLUM2
    READ (FONT2+K),COLUM0
    READ (SCANROW0+K),ROW0
    GOSUB SCANDATASIN8BITLOWBYTE
    READ (FONT0+K),COLUM3
    READ (FONT1+K),COLUM1
    READ (SCANROW1+K),ROW1
    GOSUB SCANDATASIN8BITHIGHBYTE
    LATCH = 0
    PAUSEUS 50
    LATCH = 1
    STROBE = 0
    PAUSEUS 150
    STROBE = 1
    next k
    FOR K = 8 TO 16
    LATCH = 0
    PAUSEUS 50
    LATCH = 1
    STROBE = 0
    PAUSEUS 150
    STROBE = 1
    NEXT K
    resume
    enable
    SCANDATASIN8BITLOWBYTE:
    FOR I = 0 TO 8
    S3 = colum0.0[i]
    S2 = colum2.0[i]
    S1 = row0.0[i]
    Sin3 = S3
    Sin2 = S2
    SIN1 = S1
    clock = 1
    PAUSEUS 50
    clock = 0
    NEXT I
    SCANDATASIN8BITHIGHBYTE:
    FOR I = 0 TO 8
    S3 = colum1.0[i]
    S2 = colum3.0[i]
    S1 = row1.0[i]
    Sin3 = S3
    Sin2 = S2
    SIN1 = S1
    clock = 1
    PAUSEUS 50
    clock = 0
    NEXT I
    Jan 2006
    Istanbul
    Hi chai98a,
    First of all, you should have a clear structure in your programming
    Here, I have done it for you.
    There are couple of things need to be paid attention of.
    1. You have EEPROM command to fill up the EEPROM with some values but you use this command with a constant inside the program. EEPROM can not be used inside the program; check the help file.
    2. You did not assign any variable to TMR0 interrupt flag, but you use "T0IF"; T0IF VAR INTCON.2
    3. You do not have a loop here. I guess you wanted to do something with
    WHILE 1
    WEND
    Describe what you wanted to do.
    EEPROM 0, [0,0,0,0,0,0,0,0,1,2,4,8,16,32,64,128]
    EEPROM 17,[1,2,4,8,16,32,64,128,0,0,0,0,0,0,0,0]
    EEPROM 40,[$00,$00,$00,$00,$00,$7C,$40,$40,$78,$40,$40,$7C,$00,$00,$00,$00]
    EEPROM 57,[$00,$00,$00,$00,$00,$7C,$10,$10,$10,$10,$10,$10,$00,$00,$00,$00]
    EEPROM 74,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00]
    @ Device pic16F877, XT_OSC, BOD_OFF, PWRT_ON, WDT_OFF, PROTECT_OFF,WRT_ON
    TRISA = %00000000
    TRISB = %11111111
    ADCON1 = 7
    INTCON = $A0     ' Enable TMR0 interrupts
    T0IF VAR INTCON.2
    Strobe      Var Porta.0
    Latch       var Porta.1
    Clock       Var Porta.2
    Sin3        var Porta.3
    Sin2        var Porta.4
    Sin1        var Porta.5
    Datasin3    var word
    Datasin2    var word
    Datasin1    var word
    Scanrow1    con 0
    Scanrow0    con 17
    font0       CON 40
    font1       CON 57
    font2       CON 74
    font3       CON 91
    COLUM3      VAR BYTE
    COLUM2      VAR BYTE
    COLUM1      VAR BYTE
    COLUM0      VAR BYTE
    ROW1        VAR BYTE
    ROW0        VAR BYTE
    font0X      VAR BYTE
    font1X      VAR BYTE
    font2X      VAR BYTE
    font3X      VAR BYTE
    S1          var bit
    S2          var Bit
    S3          Var bit
    I           var byte
    K           VAR BYTE
    X           var byte
    Z           var Byte
        TMR0 = 0
        Sin3 = 0
        Sin2 = 0
        SIN1 = 0
    '    WHILE 1
    '    WEND
    'What will happen here? What is it you wanted to do?  And where is the loop?
    DISABLE
    int1:
    '    TMR0 = 223
        STROBE = 1
        FOR K = 0 TO 8
            LATCH = 0
            PAUSEUS 50
            LATCH = 1
            STROBE = 0
            PAUSEUS 150
            STROBE = 1
        next k
        FOR K = 8 TO 16
            LATCH = 0
            PAUSEUS 50
            LATCH = 1
            STROBE = 0
            PAUSEUS 150
            STROBE = 1
        NEXT K
        resume
        enable
        FOR I = 0 TO 8
            S3 = colum0.0[i]
            S2 = colum2.0[i]
            S1 = row0.0[i]
            Sin3 = S3
            Sin2 = S2
            SIN1 = S1
            clock = 1
            PAUSEUS 50
            clock = 0
        NEXT I
        FOR I = 0 TO 8
            S3 = colum1.0[i]
            S2 = colum3.0[i]
            S1 = row1.0[i]
            Sin3 = S3
            Sin2 = S2
            SIN1 = S1
            clock = 1
            PAUSEUS 50
            clock = 0
        NEXT I
    May 2005
    Hi sayzer
    For "while 1" we need the program waiting for time interrupt
    Here is picture of ICD UI ,why stop at first lin of main: sub, try to add goto int1 at first line of main : still found the same..
  1. Pin won't stay high during Repeat...Until loop??
    Last Post: - 16th August 2009, 23:57
  2. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  3. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  4. Interruptus Frustratus
    Last Post: - 17th April 2009, 20:36
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 14:31
