PBP and assembler mixing - weird goings-on?
Results 1 to 3 of 3
    Aug 2005
    Default PBP and assembler mixing - weird goings-on?
    I've been dabbling with mixing some asssembler with PBP and can't understand why the following is happening... Consider this code:
    VAR BYTE loop
    main: FOR loop = 0 to n
    TOGGLE PORTb.3
    NEXT
    _fred
    clrw
    movwf (anywhere)
    movlw .255
    movwf (anywhere)
    goto _fred
    Sure enough, when this code is run, the loop executes for n times, then the code falls through into the assembly language section, but instead of looping infinitely to _fred, it pops back out and goes back to main: ???
    Why is it doing this?
    Giulio
    Mar 2006
    Default Watch Dog Timer timeout ?
    If you have the watchdog timer enabled, the processor will reset and go back to main.
    Aug 2005
    Aha! Good tip. Wasn't aware of the PBP defaults. Will try. Thanks for the reply!
    Giulio
  1. Replies: 14
    Last Post: - 4th October 2006, 06:45
  2. Newby- PBP wont compile for 18F (MPLAB)
    Last Post: - 18th December 2005, 00:30
