Math problem with string result
Results 1 to 11 of 11
    Sep 2005
    Switzerland
    The code here below is working ok but it shows
    the number not divided. (ex. 5894)
    I tried several ways to divided (ex. /60) this number and
    showing the result (Interger or with decimal) but no success.
    Bye
    Lotondo
    BAUD VAR BYTE
    LATDEC VAR BYTE[4]
    RX VAR PORTB.1 ' RX fm 232
    BAUD = 188 ' 4800,8,N,1(True,driven)
    PORTB=0
    LCDOut $FE, 1
    LCDOut $FE, $0C
    LOOP:
    SerIn2 RX,BAUD,[wait("$HOLD,"),SKIP 7,STR LATDEC\4]
    Pause 1000
    LCDOut $FE, 1
    LCDOut "RIS: ",STR LATDEC\4
    GoTo LOOP
    LATDEC var word
    SerIn2 RX,BAUD,[wait("$HOLD,"),SKIP 7,DEC4 LATDEC]
    Sep 2005
    Switzerland
    Mr_e thanks for yr reply.
    Now, if I set:
    Latfin var byte ------------------> Latfin is Always < 100
    Latfin = (Latdec /60)
    Lcdout Latfin
    Do you think I'll get 98.23 display ?
    How to get only 98 ?
    lotondo
    you'll never get any float as PBP works with integer.
    Sep 2005
    Switzerland
    I'll try like you said.
    I'll come back to you in case of any other trouble.
    Bye
    Lotondo
    Sep 2005
    Switzerland
    Here i am again !
    I partialy solved my problem but I believe it's possibile in a better way.
    As I said i'm getting a string : $HOLD,-xrt4qw5101*A
    Mister_e told me to use:
    LATDEC var word
    This works great but the 5101 has to be divided then by 10000 and multiplied by 60, the result 30 has to be shown with LcdOut.
    I was not able to make it works.
    Here what I did, it works but .............. :
    L1 VAR BYTE
    L2 VAR BYTE
    L3 VAR BYTE
    L4 VAR BYTE
    LATDEC VAR WORD
    SerIn2 RX,BAUD,[wait("$HOLD,"),SKIP 7,L1,L2,L3,L4]
    LATDEC = ((((L1-48)*1000)+((L2-48)*100)+((L3-48)*10)+(L4-48))*6)/1000
    LcdOut "Result: ", " ", #LATDEC
    Thanks for any further help
    Lotondo
    Which formula do you need?
    In the first post, you said you needed the 4 digit number divided by 60.
    5894 / 60 = 98.233
    Now it seems that multiplying by 0.006 is what you are looking for.
    5894 * 6 / 1000 = 35.364
    5101 * 6 / 1000 = 30.606
    Either way, you can still use mister_e's example instead of all the multiplications.
    LATDEC var word
    Then depending on which formula you actually need, do one of these...
    LATDEC = LATDEC * 6 / 1000
    -- OR --
    LATDEC = LATDEC / 60
  1. Line Graph, math problem...
    By TerdRatchett in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 05:20
  2. Math help please!!!
    By jbirnsch in forum mel PIC BASIC Pro
    Last Post: - 10th August 2007, 15:45
  3. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 05:39
  4. PicBasic Pro Math Problem??
    By Glen65 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 05:36
  5. PBP 16-bit ADC result math
    By sonic in forum mel PIC BASIC Pro
    Last Post: - 13th March 2005, 15:21
