I'm working on a local positioning system. I have one robot that sends a soundpulse and 3 receiver ("satalites") that receive that pulse and send all the timing data back to the robot.
I have one master receiver that has the wireless connection to the robot AND is connected (wired) to both other slave receivers. The master sends a signal to all devices (robot, and 2 slaves) to send a sound pulse or to start counting so this starts synchrome.
I have a problem with receiving the data from the slaves:
-If I give both slaves the "right" (serout2) code then the master will receive nothing and times out when trying to receive the data from the slaves
-if I give one slave(doesn't mater witch one) a "wrong" code (serout) THEN the master will time out ONLY when trying to receive the data from the bad slave and it will receive the data from the other slave
-if i give both slaves the wrong (serout) code then it will time out on both again
why doesn't it work when i give both slaves the right code? and how do i fix it?
this is my full code:
Master:
slaves (this is the code for the slaves. there are 2 small differences between the code from slave1 and slave2 (the "A" changes in "B"))Code:define OSC 20 ANSEL = 0 TRISC=%00000100 POKE $19, 7 'dEFINE CHAR_PACING 10 INCLUDE "modedefs.bas" S_In var PORTC.1 'data line to PORTC.1 on both slave receivers S_Out var PORTC.4 'data line to wireless transmitter and 'PORTC.0 on both slave receivers Led var PORTC.3 Pin Var PORTC.2 'Soundpulse In Cnt var byte ResM var word ResS1 var word ResS2 var word init: gosub Startblink input pin resM = 0 resS1 = 0 resS2 = 0 Main: SEROUT s_out, N2400,["1234rt"] 'give a signal to start a soundpulse rctime Pin, 0, resM 'record time for sound to reach this receiver pause 300 Serout2 S_Out, 17197, ["SA"] 'Give signal to slave 1 to send data SERIN2 S_in, 17197, 200, TimeOut1, [WAIT ("A"), ResS1.LOWBYTE, ResS1.HIGHBYTE] 'receive data from slave 1 S2_In: PAUSE 100 Serout2 S_out, 17197, ["SB"] 'Give signal to slave 2 to send data SERIN2 S_in, 17197, 200, TimeOut2, [WAIT ("B"), ResS2.LOWBYTE, ResS2.HIGHBYTE] 'receive data from slave 2 Dat_Send: gosub blink SEROUT s_out, N2400,["1234ul", resM.lowbyte, resM.highbyte, resS1.lowbyte, resS1.highbyte , resS2.lowbyte, resS2.highbyte] 'send all data back to robot pause 20 goto main Timeout1: resS1 = 11111 'error code for slave 1 goto S2_in Timeout2: 'error code for slave 2 resS2 = 22222 goto Dat_Send Blink: 'blink high led pause 3 low led return Startblink: 'nice blink to show the device is started for cnt = 1 to 10 high led pause 5 * (16-cnt) low led pause 5 * (16-cnt) next return
Code:define OSC 20 ANSEL = 0 TRISC=%00000100 POKE $19, 7 'dEFINE CHAR_PACING 10 INCLUDE "modedefs.bas" S_In var PORTC.0 'dataline to PORTC.4 on master receiver S_Out var PORTC.1 'dataline to PORTC.1 on master receiver Led var PORTC.3 Pin Var PORTC.2 'Soundpulse In Cnt var byte Res var word init: gosub Startblink input pin res = 0 Main: serin2 S_in, 16780, [wait("t")] 'wait counting untill soundpulse is sent rctime Pin, 0, res 'record time for sound to reach this receiver serin2 S_in, 17197, [wait("A")] 'wait to send data 'serin2 S_in, 17197, [wait("B")] this is the other code for the second slave gosub blink SEROUT2 s_out, 17197,["A",res.lowbyte,res.highbyte]'send data back to master 'SEROUT2 s_out, 17197,["B",res.lowbyte,res.highbyte] this is the other code for the second slave 'if i change this SEROUT2 to SEROUT and leave the other slave at SEROUT2 then the OTHER slave works (see post) goto main Blink: 'blink high led pause 10 low led return Startblink: 'nice blink to show the device is started for cnt = 1 to 10 high led pause 5 * (16-cnt) low led pause 5 * (16-cnt) next return
