Turbo Coding
Results 1 to 10 of 10
Thread: Turbo Coding
    obaskirt's Avatar
    obaskirt Guest
    Quote Originally Posted by BigWumpus
    Maybe you'll get more answers, if you discribe, what "turbo coding" or "turbo encoding" means !!!
    Raflex said: "Turbo codes are a class of recently-developed high-performance error correction codes finding use in deep-space satellite communications and other applications where designers seek to achieve maximal information transfer over a limited-bandwidth communication link in the presence of data-corrupting noise."
    Reflex described very well what the turbo coding means.
    I am a member of Cube Sat project in Bahcesehir University, TURKEY. We want to use turbo codes for communication.
    Turbo Coding is very computing intensive algorithm so if I can not accomplish to implement it with PIC microcontroller, which chip should I use? Or maybe I will use extra EEPROM.
    Thanks for your replies.
    Default Link to turbo code
    Jan 2006
    Istanbul
    Quote Originally Posted by obaskirt
    Turbo Coding is very computing intensive algorithm so if I can not accomplish to implement it with PIC microcontroller, which chip should I use?...
    Hi obaskirt,
    If you can divide this "intensive algorithm" into small pieces or sub-segments of math operations, then you can have many small PIC modules doing small math jobs and give you individual results.
    You can then have a master PIC collecting these individual results and have a final calculation. The whole operation will be relatively faster.
    But remember, the fastest PIC is 40Mhz I guess.
    So you need to calculate precisely what speed & instruction execution time your "intensive algorithm" requires ; if you end up with a speed requirement say 4Ghz, forget PICs and use a PC instead.
    Italy
    Here they use a TI MSP430 ultra-low-power 16-bit RISC mixed-signal processors.
    (The MSP430 is used for the flight module).
    http://www.cubesatkit.com
    Ask if you can use TI MSP430 for Turbo Coding.
    The answer will be not possible, but maybe they will put you on the right tracks.
    Remember that all this stuff must be low-power.
    http://www.cubesatkit.com/content/pu...t_pumpkin.html
    Best regards,
    Luciano
    Maybe some PIC24 or DsPIC would do... but certainely not in Basic ... for now.
    Microchip C30, Hi-Tech C support them
  1. Need help in matrix keypad coding
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 14:16
  2. need help in coding..
    By daphne8888 in forum mel PIC BASIC
    Last Post: - 19th March 2008, 08:31
  3. HPWM coding
    By civictypeR in forum mel PIC BASIC Pro
    Last Post: - 29th January 2008, 15:54
  4. Manchester coding question
    Last Post: - 5th May 2007, 18:35
  5. Turbo Encoding with Pic Basic Pro
    By obaskirt in forum mel PIC BASIC Pro
    Last Post: - 15th November 2006, 10:22
