Unused Opened Drain
Results 1 to 7 of 7
Threaded View
  1. #4
    What to do with unused pins is always a long and endless debate. Personnaly i set them as input and use external resistors OR i tie them to GND (or VSS) via 0 ohms jumper or not. YUP, i still use the old method. Same thing for CMOS or else IC. All input to somewhere.
    If the unit is not powered, the pin is not set as output so MAY act as a big antenna waiting for the next ESD... so MAY cause some problem one day or another. BUT if you consider the board layout + enclosure insulation it give you another point of view.
    It's up to you to make your own decision.
  1. 16F877A Pullups/Pulldowns and unused pins
    By DavyJones in forum General
    Last Post: - 17th April 2009, 01:39
  2. Write and Read from internal Memory
    By joseph Degorio in forum Serial
    Last Post: - 2nd December 2007, 11:03
  3. Five unused pins and one resistor
    By Cabomba in forum mel PIC BASIC Pro
    Last Post: - 27th May 2007, 18:07
  4. Unused pins
    By manxman in forum mel PIC BASIC Pro
    Last Post: - 4th May 2007, 22:24
  5. open drain output as digital output?
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 10th November 2006, 03:11
