AC Measurement
Results 1 to 19 of 19
Thread: AC Measurement
    Feb 2003
    Sydney, Australia
    It depens on the linearity of the transformer. Small transformers tend to have quite bad regulation and this can greatly affect the linearity. This is why the Elektor article had two in series so the 230v primaries were only run at 115v to move the transformers response into a more linear region.
    Best suggestion I can make it to get a voltmeter of the appropriate type and measure the mains voltage at the same time you measure the output of the transformer to see if it is linear. If you can find a variac it makes it very easy as you just ramp up/down the voltage and plot the i/p to transformer o/p ratio.
    I'll have a look for the CC info - I have found the folder with it in - Its ISSUE 164 - March 2004
    FROM THE BENCH Intelligent Current Sensing: Harness the Power of the ACS750 Hall Effect Current Sensor, by Jeff Bachiochi, p.68
    Code is at ftp://ftp.circuitcellar.com/pub/Circ...-Bachiochi.zip
    Bill.
    Wink Microchip AN's ... of course !!!
    See Here:
    http://ww1.microchip.com/downloads/e...tes/00220a.pdf
    That's the smart way ...
    Sep 2006
    Florida, USA
    Thumbs up
    Alain! Thanks for the link to the ap note! That looks like what I am trying to achieve. I have ordered the parts for the input side of the circuit as well as a variable transformer (for testing).
    Bill - I found the index listing for the article that you told me about but it is not available for viewing. Is there a way to get a copy of the article from them?
    I will try to put together the circuit from the ap note and let everyone know how it goes and post my results. Keep your fingers crossed!
    Thanks everyone!
    Sep 2006
    Florida, USA
    Talking Final Result
    Hello All - As promised, when I came up with a suitable solution, I would post it. Here it is... It works well for my application - I just need a good response between 110 and 125VAC. I used a split-bobbin transformer, bridge-rectified it and put it through a voltage divider (that has a trimmer on it so that you can adjust the output a little). Simple and cheap solution. Get nice values over the range I am interested in (about 1VDC over 15VAC range).
    Enjoy! And thanks!
    Atom058
  1. Circuit Diagram for interfacing AC to PIC IC?
    By wellyboot in forum Schematics
    Last Post: - 8th March 2008, 20:40
  2. How to read AC mains with an inductance coil
    By KB3BYT in forum mel PIC BASIC Pro
    Last Post: - 20th February 2008, 13:02
  3. AC Measurement problems
    By Charles C in forum Off Topic
    Last Post: - 25th October 2005, 18:13
  4. Special Offer AC -AC adapter
    By lester in forum Adverts
    Last Post: - 9th September 2005, 08:52
  5. Detecting AC current
    By rhino in forum Off Topic
    Last Post: - 8th July 2005, 22:31
