It was in a print edition in late 80s - let me see if I can find it in the archive and scan it. It was a mains voltage monitor in UK Elektor.Originally Posted by Atom058
The Circuit I used actually had the Maxim MX636 (I incorrectly mentioned NSC before) version of the AD636 (I used it because it was part of the free samples that were available at the time.) I used transformers for isolation as I didn't want to blow up the PIC, the computer, or myself !
Not sure of the merit of converting voltage to frequency rather than just doing an RMS measurement in either hardware or software after stepping the voltage down. Have a look at Circuit Celler a while back - Jeff Bachiette (sp?) did an article using the Alegro current sensors where he did some RMS measurements in software to work out the peak current at the peak of the mains cycle - it might help. He did it in a 12f873 using PBP. Let me go out to the shed and see if I can find the article. The code should be on the CC site.
Bill.
