AC Measurement
Results 1 to 19 of 19
Thread: AC Measurement
    Sep 2006
    Florida, USA
    Bill - Thanks for your reply. I searched a little through the Elektor Forum and was not able to find anything like what you were describing. Can you point me in the right direction? Also, after looking at the spec sheet for the LM331, can you tell me if the circuit that they have diagrammed is necessary in it's entirety? Did you have a simpler design?
    Thanks! Atom058
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1185&stc=1&d=116343790 0">
    On a PIC with ADC and comparator on the same pin it could be possible.
    Comparator interrupt to detect the zero crossing, you wait 'till 0.707 Vpeak - x offset delay, then take an ADC reading.
    OR use 2 I/o, one INT (let's say INT0) + ADC.
    But i think the poor psu may suffer if you need many mA.... Could be handy to use high efficiency LED display.
    EDIT: another maths approach using samplings... process the long RootMeanSquare stuff... or by 0.707*Vpeak.
    Sep 2006
    Florida, USA
    Steve - Thanks for the diagram. It looks to me to be a modification of the transformerless power supply with the addition of a resistor divider network to provide the input to my PIC. Is that correct?
    I don't intend to power my PIC or anything with this - so the current capability of the circuit is not important. I just need to know how to condition the AC so that I can read the voltage.
    I like your idea of triggering an interrupt (like for the AC Lamp Dimmer circuit you helped me out with), waiting a few uS and then start measuring the voltage on an ADC input. I would then find the highest value and from that I can calculate the voltage. However, I believe that I need to get the incoming voltage to the ADC pin to 5V or below. Isn't that correct? That seems to be the $64 question... how do I get the 120V AC input to some level that is acceptable for an ADC input? Is this accomplished with the resistor divider circuit that you presented?
    I appreciate your help!
    Thanks!
    Quote Originally Posted by Atom058
    In fact the Vpeak must be lower than 5 volt. So a Vac(rms) of 5*.707=3.535 Vac(rms)
    Yes. Maybe a dual secondary transformer (like the one you used for the DImmer) could work. This will also provide your insulation. So you use one output for your PIC and plah plah, the other for your reading.
    Maybe it will work good... maybe not... in theory yes... but i feel some potential bugs... interesting to know your results.
    Feb 2003
    Sydney, Australia
    Thanks! Atom058
    It was in a print edition in late 80s - let me see if I can find it in the archive and scan it. It was a mains voltage monitor in UK Elektor.
    The Circuit I used actually had the Maxim MX636 (I incorrectly mentioned NSC before) version of the AD636 (I used it because it was part of the free samples that were available at the time.) I used transformers for isolation as I didn't want to blow up the PIC, the computer, or myself !
    Not sure of the merit of converting voltage to frequency rather than just doing an RMS measurement in either hardware or software after stepping the voltage down. Have a look at Circuit Celler a while back - Jeff Bachiette (sp?) did an article using the Alegro current sensors where he did some RMS measurements in software to work out the peak current at the peak of the mains cycle - it might help. He did it in a 12f873 using PBP. Let me go out to the shed and see if I can find the article. The code should be on the CC site.
    Bill.
    Sep 2006
    Florida, USA
    Bill - Thanks for your help! That would be great if you can find that Elektor article. And the pointer to Circuit Cellar - I'll be pouring over that site...
    Steve (and/or Bill?) - I have a transformer question that hopefully you can answer: Let's say I have a transformer that takes 120VAC and gives me an output of 12VAC. If I have a 2V (1.67%) drop at the input, will I have a corresponding drop at the output (12 * 0.0167 = 0.2V)? In this case, my input would be 118VAC and my output would be 11.8VAC. If so, does anyone have a feel for how linear it is? Again, my voltage of interest is only between 115V - 125V AC.
    Thanks!
    Feb 2003
    Sydney, Australia
    It depens on the linearity of the transformer. Small transformers tend to have quite bad regulation and this can greatly affect the linearity. This is why the Elektor article had two in series so the 230v primaries were only run at 115v to move the transformers response into a more linear region.
    Best suggestion I can make it to get a voltmeter of the appropriate type and measure the mains voltage at the same time you measure the output of the transformer to see if it is linear. If you can find a variac it makes it very easy as you just ramp up/down the voltage and plot the i/p to transformer o/p ratio.
    I'll have a look for the CC info - I have found the folder with it in - Its ISSUE 164 - March 2004
    FROM THE BENCH Intelligent Current Sensing: Harness the Power of the ACS750 Hall Effect Current Sensor, by Jeff Bachiochi, p.68
    Code is at ftp://ftp.circuitcellar.com/pub/Circ...-Bachiochi.zip
    Bill.
    Wink Microchip AN's ... of course !!!
    See Here:
    http://ww1.microchip.com/downloads/e...tes/00220a.pdf
    That's the smart way ...
    Sep 2006
    Florida, USA
    Thumbs up
    Alain! Thanks for the link to the ap note! That looks like what I am trying to achieve. I have ordered the parts for the input side of the circuit as well as a variable transformer (for testing).
    Bill - I found the index listing for the article that you told me about but it is not available for viewing. Is there a way to get a copy of the article from them?
    I will try to put together the circuit from the ap note and let everyone know how it goes and post my results. Keep your fingers crossed!
    Thanks everyone!
    Sep 2006
    Florida, USA
    Talking Final Result
    Hello All - As promised, when I came up with a suitable solution, I would post it. Here it is... It works well for my application - I just need a good response between 110 and 125VAC. I used a split-bobbin transformer, bridge-rectified it and put it through a voltage divider (that has a trimmer on it so that you can adjust the output a little). Simple and cheap solution. Get nice values over the range I am interested in (about 1VDC over 15VAC range).
    Enjoy! And thanks!
    Atom058
  1. Circuit Diagram for interfacing AC to PIC IC?
    By wellyboot in forum Schematics
    Last Post: - 8th March 2008, 20:40
  2. How to read AC mains with an inductance coil
    By KB3BYT in forum mel PIC BASIC Pro
    Last Post: - 20th February 2008, 13:02
  3. AC Measurement problems
    By Charles C in forum Off Topic
    Last Post: - 25th October 2005, 18:13
  4. Special Offer AC -AC adapter
    By lester in forum Adverts
    Last Post: - 9th September 2005, 08:52
  5. Detecting AC current
    By rhino in forum Off Topic
    Last Post: - 8th July 2005, 22:31
