AC Measurement
Results 1 to 19 of 19
Thread: AC Measurement
    You could read the whole thread bellow
    http://www.picbasic.co.uk/forum/show...t=degree+60hz\
    Check the last one. I like the idea of 0.707 Vpeak but never experimented is as now. In theory and if your timings are good, it works.
    If properly design, something around the transformerless PSU idea may also works.
    have a look at this
    Default "High voltage" monitoring
    Hi, Atom
    The safe way would be :
    1) to use a Voltage to frequency converter , LM 331 i.e., on the HV side. ( after applying a, say 100v, offset to your mains ...)
    2) to transmit the freq. via an Opto-coupler ( 1Kv min rated !!! ... ) or an optic fiber to the measuring unit.
    It will be much easier to do a freq counter with the Pic ...
    Sep 2006
    Florida, USA
    Smile
    Hello All - Thanks for the replies. Using the RMS to DC converter chip as suggested by bbarney seems like the easiest way to go, but the chip costs $15 US which significantly inpacts the overall cost of my project. SO, at least for now, I am going to investigate some other options. I may come back to this if nothing else works.
    I am considering Mister_e's suggestions - the most interesting of which is the modification of the transformerless power supply (Melanie's design):
    (http://www.picbasic.co.uk/forum/atta...1&d=1139474240)
    Steve: would you care to further elaborate on that approach? Is it possible to get the 120 AC voltage down to the 5V DC range and be able to detect 1V changes in the incoming AC? The transformerless power supply has a Zener in it - if I am not mistaken, that essentially chops off voltages above it's rating (in this case, 12V).
    Acetronics: If I gather your response correctly, it sounds like you are addressing frequency measurement. At this time, I am interested in voltage measurement. Please let me know if I misunderstood...
    Again, Thanks!
    Sep 2006
    Florida, USA
    Default Melanie, you are invited, too!
    Melaine - Since this is (hopefully) a modification of your design, I thought I would invite you to participate and maybe take a break from the somewhat heated debate over fusing in the other thread... (BTW, I agree with you wholeheartedly. I was an electrical safety officer at a national laboratory here in the States, and I shut down operations at an entire facility because they used some equipment fused N:G). Aaaannywaaayy.... that's not the topic here... Can you give any comments on my objective?
    Thanks!
    Quote Originally Posted by Atom058
    Hello All
    Again, Thanks!
    Hi, Atom
    YES, you are ...
    the goal is to convert the mains dangerous voltage to a proportionnal frequency and THEN to use an opto coupler to transmit the info to a low voltage ( = safe ) part of the meter.
    so, you count a freq which is proportionnal to your voltage. C.Q.F.D.
    Sep 2006
    Florida, USA
    Alain - My apologies! After looking at the spec sheet, this does sound like a promising prospect after all. It looks like I need to get the voltage down to 10V or thereabouts to input into this chip. Is that correct? I tried searching for LM331 to see if any others have used this but could not find any reference to it. I even tried the Google search, too. Can you recommend a good way to get my incoming AC down to a level acceptable for input into this chip?
    Thanks!
    Feb 2003
    Sydney, Australia
    I have measured 240v using this IC. I used two 240v minature transformers in series across the mains to measure the voltage. This became ~6v on the (series connected) secondary side that I then fed to the NSC RMS to DC convertor IC.
    I used the 'two transformer in series' trick as I had once read about it in Elektor as a way to improve the linearity of the small cheap transformers I was using.
    It worked real well, only issue was the cost of the ICs. I also worked on doing various half wave and full wave recification schemes, but after smoothing found the lag was an issue.
    Bill
  1. Circuit Diagram for interfacing AC to PIC IC?
    By wellyboot in forum Schematics
    Last Post: - 8th March 2008, 20:40
  2. How to read AC mains with an inductance coil
    By KB3BYT in forum mel PIC BASIC Pro
    Last Post: - 20th February 2008, 13:02
  3. AC Measurement problems
    By Charles C in forum Off Topic
    Last Post: - 25th October 2005, 18:13
  4. Special Offer AC -AC adapter
    By lester in forum Adverts
    Last Post: - 9th September 2005, 08:52
  5. Detecting AC current
    By rhino in forum Off Topic
    Last Post: - 8th July 2005, 22:31
