Still new to PicBasic - i2c questions
Results 1 to 5 of 5
    cometboy's Avatar
    cometboy Guest
    Default Still new to PicBasic - i2c questions
    Thanks for getting me started on the LED blinking, finding out about the POKE command for setting the correct clock rate was a big thing for me.
    I'm using the i2cout command at this time and have a few questions.
    1) the command seems to work for some PICs but not others. I get a compiler error - undefined symbol PortA for a 12F629, but not for a 16F819.
    Is this a correct diagnosis?
    2) What kind of preliminary housekeeping commands would I need to set up the 16F819 for i2c operation. I'm sure that I have to set the clock rate (4MHz) and the PortA,0 and PortA,1 as outputs, but anything else?
    3) The command i2cout has me a little confused. The first variable is the control code, with the leading bite determining the address as word or byte. The next variable contains the i2c device address.
    I am going to be talking to a PCA9633 PWM LED driver. Theis device has no control code, only a slave address. Once the slave answers the address byte, you start feeding it data to set the LEDs.
    I have sucessfully run this device using another PIC device, the PicAxe, from England. The data sequence was ADDRESS,DATA,DATA... with no control code.
    I'm sure a lot of this is pretty inchoherent, but I'm just learning how to ask questions in PBC. I'm also working on this in parallel, so might find the answers myself. But your last answer really helped, so here I am.
    Thanks.
    Alan
    Jan 2006
    Istanbul
    Let me take number 1.
    Quote Originally Posted by cometboy
    1) ...I get a compiler error - undefined symbol PortA for a 12F629, but not for a 16F819.
    Is this a correct diagnosis?...
    Alan
    Alan,
    Check the datasheet of 12F629.
    You will see that the PORTA does not exist.
    You will see GPIO.
    PORTA is valid for 16F819. TRISA is also.
    You get these as GPIO and TRISIO for 12F629.
    May 2006
    Del Rio, TX, USA
    I'll take #3:
    The example in the PicBasic manual assumes an I2C EEPROM. So, it uses the word "control" for the device address, and "address" is the memory address inside the EEPROM. So, in your case, I would try it using the following construct:
    I2COUT address, data1, (data2, ....)
    HTH
    cometboy's Avatar
    cometboy Guest
    Default Still no i2c action
    I'm still getting no joy from the i2c command. I'm using a PIC16F819 chip with the following program.
    Using a scope on PortA,0 and 1, I see no modulation on either line. The two lines stay high from the 10Kohm pullup resistors on the slave device.
    poke $8F,%01100000 'set oscillator to 4MHz - OSCCON
    poke $03,%00110000 'set to Bank 1 - STATUS
    poke $85,%00000000 'set PortA all outputs - TRISA
    symbol addr = %00101010
    symbol blah = $80
    i2cout addr,blah,($00,%0000100,255,0,0,%10000000,$FF,$00, %10101010)
    Any clues? Thanks for the previous comments.
    Alan
    first observation, you forgot to disable the analog stuff on those Pins.
    POKE $9F,7
    And i think PBC handle the bank switch for you... i think.
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  4. i2c PBP questions
    By TimV in forum General
    Last Post: - 5th February 2007, 18:58
  5. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 14:55
