Active low input?
Results 1 to 15 of 15
    CosMecc's Avatar
    CosMecc Guest
    Here is my code, for the schematic I'm drawing it...
    '*  Name    : 7731_SigmA2D.BAS                                  *
    '*  Author  : Giandomenico Di Massa                             *
    '*  Notice  : Copyright (c) 2006                                *
    '*  Date    : 01/11/2006                                        *
    define OSC 10
    define SHIFT_PAUSEUS 20
    'LCD setup
    Define LCD_DREG	PORTB		'Set the LCD port
    Define LCD_DBIT	4			'set the fist bit for the LCD
    Define LCD_RSREG PORTB		'Set the bit Register Select port
    Define LCD_RSBIT 1			'set Register Select pin
    Define LCD_EREG	PORTB		'Set bit Enable port
    Define LCD_EBIT 2 			'Set the Enable pin
    Define LCD_BITS 4
    Define LCD_LINES 4
    'Serial Peripheral Interface setup
    symbol SCK=PORTC.6          'Clock pin
    symbol SI=PORTC.5           'AD7731 Data in pin
    symbol SO=PORTC.4           'AD7731 Data out pin
    symbol CS=PORTC.7           'AD7731 Chip select pin
    symbol RDY=PORTC.2          'AD7731 Ready pin
    'Variables declaration
    C1 Var byte
    Send Var byte               'Byte sent to the 8 bits Communication register of the AD7731
    Command var byte            'Byte sent as command to a register setted by Send in Communcation register
    Command2 var word           'Word sent to 16 bit register as Mode or Filter register of the AD7731
    Rec  VAR byte               'Byte received from AD7731:only for communication register 8 bit
    AD var word                 'AD converter value 16 bits data word
    mVolt var word
    dmVolt var word
    LCDOUT $FE,1
    input rdy
    LCDOUT "Initiating..."
    gosub waitbutton
    lcdout $FE, $C0, "OK"
    Test_communication_interface: 'Active and deactive the D0 digital line to test the AD7731 - Communication
          Send=$2               'Send command $2 hex to the communication register:next operation  is a write on Mode register
          Command2=$0B74        'Send command $0B74 hex to the Mode Register: Active Digital line, put hi the D0 output
          gosub lcdupdate
          gosub ad_write2       'Send command
          gosub waitbutton
          Command2=$0974        'Send command $0974 hex to the Mode Register: Active Digital line, put low the D0 output
          gosub lcdupdate
          gosub waitbutton
    Setup_Configuration:
          Send=$3               'Send command $3 hex to the communication register:next operation  is a write on Filter register
          Command2=$8002        'Send command $8002 hex to the Filter register: 122Hz output rate in nonCHOP mode
          gosub lcdupdate
          gosub waitbutton
    'AD7731 Self Calibration
          Command2=$91F4        'Send command $0974 hex to the Mode Register: Internal zero scale calibration
          gosub lcdupdate
          gosub waitrdy
          Command2=$B1F4        'Send command $B1F4 hex to the Mode Register: Internal full scale calibration
          gosub lcdupdate
          gosub waitrdy
          Command2=$D1F4        'Send command $D1F4 hex to the Mode Register: System zero scale calibration
          gosub lcdupdate
          gosub waitrdy
          Command2=$F1F4        'Send command $F1F4 hex to the Mode Register: System full scale calibration
          gosub lcdupdate
          gosub waitrdy
          lcdout $FE,$1
    Loop:
          command2=$50F4        'Send command $50F4 hex to the Mode Register: Single conversion,Range 0-1.28V, Data length 16 bit, AIN1-AIN2 Full Differential
          gosub waitrdy
          gosub ad_read                             'Read the Data Registaer
          lcdout $FE, $80,"Rec:",hex ad,"    "
          lcdout $FE,$80+10," AD:",dec ad,"    "
          lcdout $FE,$C0,"Ad:",bin16 ad
          mvolt = ad*195                            'Scale the 16 bit value to milliVolt
          mvolt=div32 10000
          dmvolt=R2/100
          lcdout $FE,$94,"Volt:",dec mvolt,",",dec2 dmvolt, " mV     "
          pause 300
     goto loop
    AD_Write2:
    'AD7731 write routine into a 16 bit register as Mode register
    'first byte is sent to the Communication register for the register selection
    'second word od 16 bit is value to be sent
    'this routine is valid only for writin in 16 bits registers
        low cs                          'Enable Device
        shiftout so,sck,1,[send\8]      'Send the command to the communication register: write enable command
        shiftout so,sck,1,[command2\16] 'Send the command to the 16 bit register
        high cs                         'disable the device
    AD_Read:
        low cs
        shiftout so,sck,1,[$11\8]
        shiftin si,sck,0,[AD\16]
        high cs
    WaitButton:
       button PORTC.3,255,0,0,C1,1,GoOut
       goto waitbutton
    GoOut:
    LCDupdate:
    	LCDOUT $FE,1
        lcdout "Comm. register: ", hex send,$FE, $C0,BIN8 send
        lcdout $FE, $94,"Command: ",hex command2 , $FE, $D4,bin16 command2
    WaitRDY:
        while rdy=1
        wend
    CosMecc's Avatar
    CosMecc Guest
    Here is the scheme...
    thanks
    CosMecc's Avatar
    CosMecc Guest
    does any one has experience with this ADC?
    If i refer to the datasheet, they suggest 33pF capacitor wit a 4.9152MHz crystal.
    Try increasing the capacitor value first.
    CosMecc's Avatar
    CosMecc Guest
    Do you think that the cap difference could be the cause of the ADC instability?
    Talking
    could be... i've never use this converter, i'm not on your bench, i don't see how you place it on your board (prototype or not) and unfortunately my scope probe are not long enough to reach you
    could also be the supply line, wind direction or alien invasion... who knows ?
    CosMecc's Avatar
    CosMecc Guest
    Angry
    I'm trying with 33pF cap, but nothing new
  1. Sony LanC Program
    By l_gaminde in forum Code Examples
    Last Post: - 25th September 2009, 18:51
  2. RB0 + Internal Pullup + Interrupt
    By Freman in forum mel PIC BASIC Pro
    Last Post: - 10th August 2009, 11:11
  3. Old and beyond help ?
    Last Post: - 11th December 2008, 15:23
  4. Serial Question + General Review
    By Freman in forum General
    Last Post: - 20th June 2008, 22:27
  5. 4-line LCD Help - using PortA instead of B
    Last Post: - 31st March 2005, 03:14
