Moving message on LED dot matrix
Results 1 to 13 of 13
    May 2005
    Default Moving message on LED dot matrix
    Dear friend Microcode used
    Now we study moving message on LED dot matrix but did not work.
    We have sample in code (CSS) but i not under stand on code need you help to conver c code to basic code.
    CodeCSS )
    #include <16F877.h>
    #fuses HS,NOWDT,NOPROTECT,PUT,NOLVP
    #use delay(CLOCK = 10000000 )
    #use fast_io(B)
    #bit STROBE = 0x06.0 //PIN_B0
    #bit LATCH = 0x06.1 //PIN_B1
    #bit CLOCK = 0x06.2 //PIN_B2
    #bit SIN3 = 0x06.3 //PIN_B3
    #bit SIN2 = 0x06.4 //PIN_B4
    #bit SIN1 = 0x06.5 //PIN_B5
    // | SIN2 | SIN3 |
    // | Colum3 | Colum2 | Colum1 | Colum0 |
    // |7 6 5 4 3 2 1 0 | 7 6 5 4 3 2 1 0 | 7 6 5 4 3 2 1 0 | 7 6 5 4 3 2 1 0 ------
    // | | | | 1 |
    // | | | | 2 |
    // | | | | 3 |
    // | | | | 4 | ROW0
    // | | | | 5 |
    // | | | | 6 |
    // | | | | 7 |
    // |----------------|-----------------|-----------------|----------------------- SIN1
    // | | | | 0 |
    // | | | | 1 |
    // | | | | 2 |
    // | | | | 3 |
    // | | | | 4 | ROW1
    // | | | | 5 |
    // | | | | 6 |
    // | | | | 7 |
    char const font[3][16] =
    {0x00,0x00,0x00,0x00,0x00,0x7C,0x40,0x40,0x78,0x40 ,0x40,0x7C,0x00,0x00,0x00,0x00}, //E
    {0x00,0x00,0x00,0x00,0x00,0x7C,0x10,0x10,0x10,0x10 ,0x10,0x10,0x00,0x00,0x00,0x00} //T
    {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 ,0x00,0x00,0x00,0x00,0x00,0x00} //Space
    char const ScanRow1[16] =
    0,0,0,0,0,0,0,0,1,2,4,8,16,32,64,128
    char const ScanRow0[16] =
    1,2,4,8,16,32,64,128,0,0,0,0,0,0,0,0
    int buffer[4][16];
    int Colum3,Colum2,Colum1,Colum0,Row1,Row0;
    //int CheckClock,ValueBitSIN3,ValueBitSIN2,ValueBitSIN1;
    int k,l,m,n,o,p,q;
    void SendData16Bit();
    void SendDataSIN8BitHighbyte();
    void SendDataSIN8BitLowbyte();
    void BeginData();
    void ClearData();
    #INT_TIMER1
    void IntTimer1_isr()
    STROBE = 1; //STROBE OFF
    for (k=0;k<8;k++) // Row 0 to 7
    Colum2 = buffer[2][k];
    Colum0 = buffer[0][k];
    Row0 = ScanRow0[k];
    Colum3 = buffer[3][k];
    Colum1 = buffer[1][k];
    Row1 = ScanRow1[k];
    LATCH = 0; //LATCH ON
    LATCH = 1; //LATCH OFF
    STROBE = 0; //STROBE ON
    delay_us(50);
    for (k=8;k<16;k++) // Row 8 to 15
    Row0 = ScanRow0[k];
    Row1 = ScanRow1[k];
    delay_us(50);
    //STROBE = 0; //STROBE ON
    //set_timer1(65451); // FF AB interrupt 34uS
    set_timer1(65400);
    void main()
    set_tris_b(0x00);
    enable_interrupts(INT_TIMER1);
    enable_interrupts(GLOBAL);
    setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
    CLOCK = 0; //Clock OFF Active High
    SIN3 = 0; //S-IN3 OFF
    SIN2 = 0; //S-IN3 OFF
    SIN1 = 0; //S-IN3 OFF
    ClearData();
    BeginData();
    //LOOP
    while(1)
    for(p=0;p<8;p++)
    for (n=0;n<16;n++)
    buffer[3][n] = ((buffer[3][n]) * 2) + (((buffer[2][n]) &0B10000000)/128) ; //colum3
    for (n=0;n<16;n++)
    buffer[2][n] = ((buffer[2][n]) * 2) + (((buffer[1][n]) &0B10000000)/128) ; //colum2
    for (n=0;n<16;n++)
    buffer[1][n] = ((buffer[1][n]) * 2) + (((buffer[0][n]) &0B10000000)/128) ; //colum1
    for (n=0;n<16;n++)
    buffer[0][n] = ((buffer[0][n]) * 2) + (((buffer[3][n]) &0B10000000)/128) ; //colum0
    delay_us(100);
    int i;
    for(i=0;i<8;i++)
    SIN3 = bit_test(Colum1,(i));
    SIN2 = bit_test(Colum3,(i));
    SIN1 = bit_test(Row1,(i));
    CLOCK = 1; //Clock ON
    int i;
    for(i=0;i<8;i++)
    SIN3 = bit_test(Colum0,(i));
    SIN2 = bit_test(Colum2,(i));
    SIN1 = bit_test(Row0,(i));
    void BeginData()
    for (n=0;n<16;n++)
    buffer[0][n] = font[2][n]; // Space
    for (n=0;n<16;n++)
    buffer[1][n] = font[1][n]; // T
    for (n=0;n<16;n++)
    buffer[2][n] = font[1][n]; // T
    for (n=0;n<16;n++)
    buffer[3][n] = font[0][n]; // E
    //for (n=0;n<16;n++)
    // buffer[4][n] = font[2][n]; // Space
    void ClearData()
    for(l=0;l<4;l++) // clear buffer
    for (m=0;m<16;m++)
    buffer[l][m] =0;
    I suggest you download the CCS documentation + their Demo and try to understand what it does yourself first.
    Or like i said in another thread... pay someone here
    Out of curiosity.. is this for a school work?
    Feb 2005
    Kolkata-India
    Red face If you come up with the circuit I may help
    I have done a moving display with PBP but cannot share it due to commercial restrictions. If you are using Shift Registers then the idea is :
    1. Get the font data from a lookup table
    2. Dump column data for every row and light up that row, do it in even periods and you have got the scanning.
    3. For moving message use a pointer in your message table and update it at regular intervals to scroll.
    I know that this is very rudimentary. Post your schematic and I will try to help. I got the lookup table for the 5x7 matrix from this forum by dave and thankful for the same. So perhaps its my turn.
    Sougata
    May 2005
    Hi sougata
    Here is picture of circuit 512 ...
    There are 8 pin for control
    Strobe = control On/Off Dot matrix led display, logic "0" active led on
    Latch = control data transfer logic "0"
    Clock = clock
    Sin1 = control row0,row1
    Sin2 = control culum2 , culum3
    Sin3 = control culum0 , culum1
    Vcc_led = power +5 v
    Vcc_IC = power +5 v
    brighton
    Thumbs down
    From your post i can see that you have a 16 row by 32 Cols
    the easy way i would have dont this is use PortB & Portc for for Rows
    Then use 4 74hc595 shift reisters for your cols to give you 32bits then use the shiftout command.
    Here is an example of an 8 Row by 16 Cols
    i used portb for the Rows and 2 74hc595 for the cols
    This should get you started
    ' Program USING 74HC595 .BAS
    INCLUDE "Modedefs.bas"
    ADCON1=7
    TRISA=0:TRISB=0:TRISC=0
    'PORT ASSIGNS******************************************* ***
    DataP VAR PORTC.0'Data pin (74x595.14)
    Clk VAR PORTC.1'shift clock (74x595.11)
    Latch VAR PORTC.2'Output Latch(74x595.12)
    RowVAR BYTE
    'Variables ***********************************************
    Delay CON 0'Delay
    pattern VAR WORD 'Output pattern
    A VAR BYTE ' Loop counter for 16 values of Rows
    Pause 1000
    Low Latch
    main :
    pattern = %0000000000000001 'pattern for my columns
    For A=0 To 15 ' set the Count 16 times
    LookUp A,[0,255,255,24,24,255,255,0,0,255,255,219,219,195,19 5,0],Row
    'Those values in the Table should give HE on your display
    ShiftOut DataP,Clk,msbFirst,[pattern\16] 'Send pattern to 74x595
    PORTB=0 'Blank portb before changing
    column
    PulsOut Latch,1 'Latch 74x595 outputs
    PORTB=Row 'Transfer values from table to
    portb
    Pause Delay 'Delay
    pattern=pattern <<1 'shift pattern 1 place the to left
    Next A 'this should give me 0000000000000001 to 1000000000000000
    GoTo main
    Isaac
    May 2005
    How to set like becode with PBP....
    Now we used lookup but we cannot specify line or font number
    brighton
    you are mixing pbp with c ?
    brighton
    why not use the data command and prewrite the data to eeprom
    Isaac
    Char var byte[48]
    char[0]=
    char[1]=
    char[2]=
    char[3]=
    char[4]=
    or have a look HERE
    and HERE
    May 2005
    Thank all friend for advise
    I have question ..
    I would to know valve of each bit of A (see below)
    A con % 10010111
    A bit 0 = 1
    A bit 1 = 1
    A bit 2 = 1
    A bit 3 = 0
    A bit 4 = 1
    we write as below but not work...
    A con % 10010111
    For i = 0 to 8 ' loop for bit number
    x [i] = A.[i]
    print x[i]
    next i
    Sorry .... it may not cler for my question ( I don't how to say)
    xVar=A.0[i]
    And 'print' is not a Melabs PicBasic statement
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. LCD will not start
  4. Flashing!! LED Dot matrix problem
    Last Post: - 4th December 2006, 10:45
  5. matrix led array( moving singboard )
    By ufuk0106 in forum mel PIC BASIC Pro
    Last Post: - 11th April 2005, 18:42
