sdata,sclk same port?
Results 1 to 4 of 4
    Jul 2006
    Default sdata,sclk same port?
    Hello
    Must the data and clock from eeprom like 24c16 conected to the same
    port on the pic device?
    I have connect in my board the data and clock to diferent ports and
    it not function everytime correctly, it this possible?
    Regatds
    Pedro
    Jan 2006
    Istanbul
    It should be ok.
    Why don't you post your code here?
    you may be having a change on pins somewhere and that may be causing the problem.
    Since you say it works sometime, most likely you have an issue with your code if not with hardware.
    CosMecc's Avatar
    CosMecc Guest
    Post
    If you use a demo board it could be a false contact
    OR your i/o may have some multiplexed stuff on... let's says ADCs or Comparator.
  1. Why (or how to) make a port array for OW
    By Roy___ in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2009, 23:30
    Last Post: - 14th November 2008, 17:25
  3. port config.
    By tamertokgoz in forum mel PIC BASIC Pro
    Last Post: - 25th July 2008, 12:25
  5. STATUS re-curtain W
    By zugvogel1 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2005, 15:21
