Servo control / UART / SPI help needed
Results 1 to 11 of 11
    Jan 2006
    Istanbul
    Quote Originally Posted by keithdoxey
    A 10mS pause is easy.... PAUSE 50
    Because your PIC is running 5 times as fast as the compiler thinks it is, all delays will be a fifth of what it expects so the 50mS pause will become 10mS.
    This is not valid for PAUSE command. It is for PULSOUT type of commands.
    Quote Originally Posted by Blackhawk
    I want a 10 microsecond pause not a 10 millisecond pause, that's the problem
    With at least 10Mhz OSC, 10uS pause can be achieved using PAUSEUS command. Since you are using 20Mhz, it WOULD BE ok in your case by PAUSEUS 10 but you are not using PBP. So it won't be possible until you get PBP.
    Therefore, you will need to use ASM routine to create a sensitive uS delay.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Quote Originally Posted by sayzer
    Not so - try this (with 20Mhz xtal 4 instructions = 1 uS)
    Gosub Delay_10	' 10 uS delay
    Gosub Delay_1 	' 1 us delay
    GOTO Main
    ' *** Delay 10 us Subroutine (2 instructions to get here and 2 to get back)
    Delay_10:
    Gosub Delay_1
    Gosub Delay_1
    Gosub Delay_1
    Gosub Delay_1
    Gosub Delay_1
    Gosub Delay_1
    Gosub Delay_1
    Gosub Delay_1
    Gosub Delay_1
    ' *** Delay 1 us Subroutine (2 instructions to get here and 2 to get back)
    Delay_1:
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Jan 2006
    Istanbul
    hehe
    Clever!
    Blackhawk's Avatar
    Blackhawk Guest
    Thanks for the help, I was wondering if I could uselessly move bits around to get the delay but I didn't know exactly how long the processes would take.
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 09:40
  2. Replies: 10
    Last Post: - 26th May 2008, 08:00
  3. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 19:15
  4. Servo control woes
    By Eriswerks in forum mel PIC BASIC Pro
    Last Post: - 28th February 2006, 01:12
  5. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 09:18
