Servo control / UART / SPI help needed
Results 1 to 11 of 11
    Blackhawk's Avatar
    Blackhawk Guest
    Quote Originally Posted by Dave
    Blackhawk, As sayzer said if you could please give us some more definition of your problem it would help. What I don't understand is the phrase "- PIC16F877a at the core, running at 20MHz (first annoyance as PICBASIC does not allow for changing xtal speeds, everything runs 5 times faster than it should)." Do you want the pic to run slower or faster? Also I don't understand the phrase "I can't actually manually drive the servos because PICbasic only lets you delay for integer milliseconds" There is a 16 bit timer or 2 inside the 16F877 which will allow 1 tick to be as small as the osc freq. / 4. Also there is a PAUSEUS command that will allow timing to about 2uS. Which 16 bit A to D convertor are you using?
    Remember I'm not using the pro version of the compiler!
    There is no way to set the oscillator frequency for your circuit, so while my oscillator is a 20MHz crystal the program is compiled for a 4MHz crystal. As such any compiled delay will be 5 times shorter than it should be.
    Also there is no pauseus command in the non-pro version of the compiler, only the command pause which only pauses down to integer milliseconds.
    I have not chosen the A/D converter yet because I was wondering if anyone here would be able to help me with the transfer protocol. How exactly would I set up a serial interface to receive a 16bit word instead of 2 8bit bytes?
    The main problem I think you people are having with understanding my issues is that you all have the pro version of the compiler, if I had the pro version I would have no problems.
    Feb 2003
    A 16 bit word is sent as two bytes because the registers in the UART are 8 bit. Send the two bytes and reassemble them into a word at the far end
    A 10mS pause is easy.... PAUSE 50
    Because your PIC is running 5 times as fast as the compiler thinks it is, all delays will be a fifth of what it expects so the 50mS pause will become 10mS.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Blackhawk's Avatar
    Blackhawk Guest
    I want a 10 microsecond pause not a 10 millisecond pause, that's the problem.
    As for the serial sending, look up the datasheet for the TLC4541, one of the ADC's I was considering. It sends it's word output as a single, un-broken word, not as two bytes with a stop bit in between, that is my problem.
    Jan 2006
    Istanbul
    Quote Originally Posted by keithdoxey
    This is not valid for PAUSE command. It is for PULSOUT type of commands.
    Quote Originally Posted by Blackhawk
    With at least 10Mhz OSC, 10uS pause can be achieved using PAUSEUS command. Since you are using 20Mhz, it WOULD BE ok in your case by PAUSEUS 10 but you are not using PBP. So it won't be possible until you get PBP.
    Therefore, you will need to use ASM routine to create a sensitive uS delay.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Quote Originally Posted by sayzer
    Not so - try this (with 20Mhz xtal 4 instructions = 1 uS)
    Gosub Delay_10	' 10 uS delay
    Gosub Delay_1 	' 1 us delay
    GOTO Main
    ' *** Delay 10 us Subroutine (2 instructions to get here and 2 to get back)
    Delay_10:
    Gosub Delay_1
    Gosub Delay_1
    Gosub Delay_1
    Gosub Delay_1
    Gosub Delay_1
    Gosub Delay_1
    Gosub Delay_1
    Gosub Delay_1
    Gosub Delay_1
    ' *** Delay 1 us Subroutine (2 instructions to get here and 2 to get back)
    Delay_1:
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Jan 2006
    Istanbul
    hehe
    Clever!
    Blackhawk's Avatar
    Blackhawk Guest
    Thanks for the help, I was wondering if I could uselessly move bits around to get the delay but I didn't know exactly how long the processes would take.
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 09:40
  2. Replies: 10
    Last Post: - 26th May 2008, 08:00
  3. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 19:15
  4. Servo control woes
    By Eriswerks in forum mel PIC BASIC Pro
    Last Post: - 28th February 2006, 01:12
  5. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 09:18
