Servo control / UART / SPI help needed
Results 1 to 11 of 11
    Blackhawk's Avatar
    Blackhawk Guest
    Default Servo control / UART / SPI help needed
    The current project I am working on is a rocket datalogger/control system and I've been running into walls all throughout PICBASIC.
    The basic specs for the whole system are as follows:
    - PIC16F877a at the core, running at 20MHz (first annoyance as PICBASIC does not allow for changing xtal speeds, everything runs 5 times faster than it should).
    - 16 channel multiplexer feeding a 16 bit ADC. I don't care if the ADC output is serial or parallel or any other strange protocol, however it needs to be capable of at least 2ksps. Clearly parallel would be easier for me to code but it's giving me other I/O problems. As for serial data transfer I'm not sure how I can get the PIC to interface with the ADC in either multi-line serial, SPI etc communication. My main problem is that the ADC is looking to directly output a word variable whereas the PIC serial coms only take byte variables directly. I could bit bash but I would REALLY hate to do that.
    - Store data in a bank of 8 I2C eeproms. Not much of an issue, have to hack around in the include files to change the I2C port to the correct port and pins though, a pain but I can live with it.
    - Control 4 servo motors. Not an issue if I have portB clear, however assuming I'm using the USART port on the PIC I only have one full 8 I/O port left, this isn't enough if I'm using a parallel 16bit ADC. Clearly the solutions are to either control the servos directly through code or use a serial ADC. Failing me learning how to manipulate 16bit serial communication with an 8bit core I can't actually manually drive the servos because PICbasic only lets you delay for integer milliseconds, enough to run a servo from full to opposite full. Even knowing that my clock speed is actually going to be 5 times faster, so I can time down to 200 microseconds doesn't really help because this doesn't give me any resolution. Last ditch effort I suppose would be to connect the servos through a smaller PIC on portb, and to communicate to that PIC via serial but that's messy every way you look at it.
    I'm only a student and this is just a hobby so I can't afford the pro version, I probably would have bought it initially however if I knew exactly how shocking the basic version is when dealing with more than turning LED's on and off.
    Jan 2006
    Istanbul
    If you could list down your questions, it would be a lot easier to understand what you want to have.
    It is being more complicated the way you described above.
    Blackhawk's Avatar
    Blackhawk Guest
    ok here goes:
    1) Is there any way I can use the hardware communication of the 16F877a (USART, SPI etc) to communicate with a 16bit ADC, which wants to send its data as words.
    2) If not, is there any way of controlling servo motors without using portB. For example can I somehow make my PIC accurately control pulses of 10 microseconds or so, without using the pulseout command (which is tied to portB only).
    That’s basically it.
    Blackhawk, As sayzer said if you could please give us some more definition of your problem it would help. What I don't understand is the phrase "- PIC16F877a at the core, running at 20MHz (first annoyance as PICBASIC does not allow for changing xtal speeds, everything runs 5 times faster than it should)." Do you want the pic to run slower or faster? Also I don't understand the phrase "I can't actually manually drive the servos because PICbasic only lets you delay for integer milliseconds" There is a 16 bit timer or 2 inside the 16F877 which will allow 1 tick to be as small as the osc freq. / 4. Also there is a PAUSEUS command that will allow timing to about 2uS. Which 16 bit A to D convertor are you using?
    Blackhawk's Avatar
    Blackhawk Guest
    Quote Originally Posted by Dave
    Remember I'm not using the pro version of the compiler!
    There is no way to set the oscillator frequency for your circuit, so while my oscillator is a 20MHz crystal the program is compiled for a 4MHz crystal. As such any compiled delay will be 5 times shorter than it should be.
    Also there is no pauseus command in the non-pro version of the compiler, only the command pause which only pauses down to integer milliseconds.
    I have not chosen the A/D converter yet because I was wondering if anyone here would be able to help me with the transfer protocol. How exactly would I set up a serial interface to receive a 16bit word instead of 2 8bit bytes?
    The main problem I think you people are having with understanding my issues is that you all have the pro version of the compiler, if I had the pro version I would have no problems.
    Feb 2003
    A 16 bit word is sent as two bytes because the registers in the UART are 8 bit. Send the two bytes and reassemble them into a word at the far end
    A 10mS pause is easy.... PAUSE 50
    Because your PIC is running 5 times as fast as the compiler thinks it is, all delays will be a fifth of what it expects so the 50mS pause will become 10mS.
    Keith
    www.diyha.co.uk
    www.kat5.tv
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 08:40
  2. Replies: 10
    Last Post: - 26th May 2008, 07:00
  3. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 18:15
  4. Servo control woes
    By Eriswerks in forum mel PIC BASIC Pro
    Last Post: - 28th February 2006, 00:12
  5. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 08:18
