open drain output as digital output?
Results 1 to 8 of 8
    Nov 2004
    Calabasas, CA
    Default open drain output as digital output?
    Will a port pin that is an "open drain output" support a SEROUT command?
    The pin in question RA4 is multiplexed with a Timer0 module clock input. Can it still be used as a digital pin?
    Will a SEROUT command set the pin digital output even if the pin was previously set as analog input?
    James
    Bombay, India
    Sure this does not apply generally to all Pics. Can you specify the device you talk about?
    Jerson
    Nov 2004
    Calabasas, CA
    Microchip PIC16C716
    James
    droptail, just use a pullup resistor of about 2.7k to 4.7k.
    Yes for sure, use Dave's suggestion.
    Yes
    Nope, this is also why we see many question about that. Always make sure you disable multiplexed stuff(when possible) on an i/o before using it.
    ADCs/analog comparator are popular.
    Nov 2004
    Calabasas, CA
    I have success with 1k hold up for now.
    I also have no problems for years with SEROUT command working on a port pin set as analog and input, why?
    TRISA =255 'all PortA Inputs
    ADCON1 =0 'all PortA Analog
    SerOut PORTA.0,N2400 ...
    James
  1. Serious Serial Situation Setbacks...
    Last Post: - 7th February 2007, 03:46
  2. Replies: 0
    Last Post: - 15th December 2006, 19:16
  3. Rx433 linear and digital output
    By mbw123 in forum mel PIC BASIC Pro
    Last Post: - 29th October 2006, 21:26
  4. HSEROUT Newbie question/problem
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 11th July 2006, 14:44
  5. Digital Compass Project
    By BJSmith in forum Serial
    Last Post: - 7th April 2006, 19:32
