PIC18F452 bootloader from MMC-card
Results 1 to 3 of 3
    Tallinn, Estonia
    Default PIC18F452 bootloader from MMC-card
    Hi!
    I needed such code for one project but..net was full of "usual" serial bootloaders. So i was forced to write it. Hope, this example will help somebody!
    Code (source in assembly and .hex file) here: http://parsek.yf.ttu.ee/~felc/PIC/bootloader.zip
    Since all comments in source are presently in my native tongue (will translate, if thread looks useful), some explanation could be useful.
    Code is located form adr 0x7000 upwards. There are 2 ways to access it:
    - by jumping to label "errorloader" - first file with name "codexxxx.hex" found on the MMC is flashed to PIC.
    - by calling to label "bootloader". In this case file parameters (all 32 bytes read from catalog entry) must be saved to buffer "File_Name".
    In both cases flashing will be attempted again and again in case of read errors and/or power failures (bootloader will write a "goto errorloader" command to the reset vector. User code will be written there only in case of successful flashing.
    Code reads standard Intel .hex files.Any data mentioned to be written above 0x7000 will be ignored.
    PIC's internal EEPROM and conf. bits will be written in accordance to source file.
    Actually...I am aware that this is not very close to PICBasic. Moderators, please forgive me....
    2solar's Avatar
    2solar Guest
    Hello, i just found this post. It sounds very interesting. Please correct your link, because i can't download your code.
    Tallinn, Estonia
    Hi!
    Checked, link works OK. could be some server problem,so i uploaded the code to forum directly. Have fun!
    /Felch
  1. SD or MMC card as storage for logging
    By HYETİK in forum mel PIC BASIC Pro
    Last Post: - 16th January 2012, 03:07
  2. PIC18F4680 bootloader
    By vinyl_theif in forum General
    Last Post: - 29th January 2009, 18:45
  3. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  4. Bootloader Problems
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 11th February 2005, 18:51
  5. Reading Magnetic Card on Pic16f876
    By Finn in forum mel PIC BASIC Pro
    Last Post: - 5th February 2004, 00:36
