On Interrupt
Results 1 to 7 of 7
Thread: On Interrupt
    Dec 2005
    Corum,Turkiye
    Default Right...
    Hi ,
    Mister_e;
    interrupt ll be for usart.....
    My code is godd running. but i want to send data from pc and when send will data from pc goto serin routine and write eprom
    Joe S. ;
    i m using 18f452
    and 10 MHz quartz. and config is hs_pll ( 10 x 4 = 40 mHz )
    so baud= 2400 x 4 = 9600 ( i hope )
    So your PIC have a Hardware USART, use it and use it's interrupts.
    Use HSERIN instead of SERIN as it use the PIC Usart.
    Maybe the following may help.
    http://www.picbasic.co.uk/forum/show...1&postcount=11
    You just need to set you USART register for the Right baudrate
    something like
    RCSTA = $90 ' Enable serial port & continuous receive
    TXSTA = $20 ' Enable transmit, BRGH = 0
    SPBRG = 64  ' 9600 Baud @ 0.16%
    OR
    DEFINE HSER_SPBRG 64  ' 9600 Baud @ 0.16%
    Dec 2005
    Corum,Turkiye
    Angry doesn't work...
    Hi, i write this codes but... i think interrupt is not working and data is not send from pc to pic eprom..
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_CLROERR 1
    RCIF VAR PIR1.5
    EOM con ""
    bilgi var byte
    b var byte
    start:
    if RCIF then ' incomming data?
    HSERIN [bilgi]
    if bilgi= "@" then
    goto pctalk
    goto start
    ... other codes
    pctalk:
    getserial:
    HSERIN [bilgi]
    write b, bilgi
    if bilgi = EOM then
    Goto start
    B = b + 1
    goto getserial
    Consider...
    HSERIN [bilgi]
    ... at 9600 baud means you're sending 9600 bits in a second... for arguments sake, say it takes 10 bits for one byte (with start and stop bits), so it takes less than 1mS per byte to receive...
    And now...
    write b, bilgi
    ...takes 10mS to write to EEPROM...
    So for every ONE byte you save to EEPROM, using your code/method at only 9600 baud will ensure you lose the following 10/12 bytes of incoming data. Can you now see it's not so straightforward to receive RS-232 and write it to EEPROM... as you have to make sure that when you write to your EEPROM you're still going to grab any incoming data that may be arriving at the same time.
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  2. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 18:14
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 02:59
    Last Post: - 6th March 2005, 01:07
