DS18B20 Busy Flag
Results 1 to 2 of 2
    Default DS18B20 Busy Flag
    I don't believe this is possible but I thought I should ask just to be sure. When running the DS18B20 in parasite power mode is it possible to check the sensor to see if it is still busy doing the temp conversion? I know the dq needs to pulled to the rail during the conversion but I was wondering if it could be released, checked and re-applied before the chip lost power.
    Jan 2006
    Istanbul
    Hi CocaColaKid,
    Some parts from Data Sheet:
    If the DS18S20 is powered by an external supply, the master can issue read time slots after the Convert T command and the DS18S20 will respond by transmitting 0 while the temperature conversion is in progress and 1 when the conversion is done. In parasite power mode this notification technique cannot be used since the bus is pulled high by the strong pullup during the conversion.
    So you are right.
  1. Please help with code for DS18B20
    Last Post: - 28th April 2013, 22:12
  2. Help with DS18B20 program
    By presario1425 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2012, 01:50
  3. Ds18b20 + 16f628a
    By Max Power in forum mel PIC BASIC Pro
    Last Post: - 16th July 2009, 12:29
  4. ELSEIF Block Would be Good.
    By T.Jackson in forum PBP Wish List
    Last Post: - 14th May 2007, 04:36
  5. DS18B20 and PIC18F4550
    By sjohansson in forum mel PIC BASIC Pro
    Last Post: - 19th April 2006, 20:57
