Microchip AN615
Results 1 to 18 of 18
Thread: Microchip AN615
    Jun 2006
    Bangalore, India
    Question
    Ya i need to make these circuits at a low cost...
    Actually i am facing a major problem with chips that do not have a TMR0 interrupt (12C508A).
    All the devices need to have a basic accurate clock running in the background.
    How can a implement a hour minute clock on PICs which do not have the TMR0 interrupt (but have timer0) and do other stuff also without much interference from the clock routine?
    Is there a way i can do it in PICBASIC PRO ???
    I never found a PIC with a accurate internal clock. It shift at least with temperature.
    You can still skip the interrupt and use MPASM Stopwatch (or else) to trim your program timing using a simple loop.
    Wink THE Gag ...
    Hi, Steve
    IF you want a program for a real time clock ( trimmable ) with a lonesome 12C50x ...
    I Have !!!
    hi,Hi ...
    OK, there's a trick somewhere ... but it works !!!
    PS: Even OTP device programs can be modified ( "1"s can be overwritten by "0"s ) ... do not repeat it !!!
    Jun 2006
    Bangalore, India
    Post
    Can anyone give me a piece of code that can do the time keeping in PICBASIC without using interrupts ? ? ? Even if it just detects the roll-over and polls a flag, it'll do...
    I wrote a PICBASIC code for a digital clock without interrupts.
    No matter what prescaller i select, the clock runs 3 times slower.
    I check the timer roughly every 50 instructions for a roll-over (By checking the MSB). . .
    When i enable interrupts for the same code with same prescaler, it works fine.
    Mar 2006
    Hyderabad (India)
    Hi
    try out latest version 16f54 as anyhow you have to programm few times to before you freeze the software-- it will help you being a flash device-- yesy one off costly and later as you finish you can finally use 16c54--
    i have piece working with clk8.asm file as provded in the application note. Reg 12hr mode -yes let me also try
    Sarma
    Jun 2006
    Bangalore, India
    Talking I've done it ! ! !
    Hey everyone,
    I finally got the clock running, without using any interrupts !!!
    Its giving equal accuracy as the one using Instant interrupts . . .
    Now next i'm going to make a 4 segment led clock using the PIC12C508A.
    Using the 12C508A, i can make a complete clock for less than $1.49 ! ! !
    Jan 2006
    Istanbul
    Quote Originally Posted by shahidali55
    Using the 12C508A, i can make the clock for less than $0.59 ! ! !
    How will you use 12C508A to drive 4 segments?
    You need 8 pins for LEDs and 4 pins for the commons; Totally 12 pins.
    Will you use a serial 4x7 LED display?
    If yes, it won't save you much money.
  1. Microchip Code Issues
    By Destovi in forum General
    Last Post: - 20th March 2008, 13:32
  2. PBP is no longer a stranger to Microchip
    By MarioC in forum mel PIC BASIC Pro
    Last Post: - 12th March 2008, 22:59
  3. Microchip Ethernet controllers
    By Philip in forum Documentation
    Last Post: - 2nd November 2007, 01:30
  4. Replies: 1
    Last Post: - 22nd June 2007, 00:57
  5. Microchip PIC silicon Revs's
    By fbraun in forum mel PIC BASIC Pro
    Last Post: - 1st March 2005, 15:07
