Microchip AN615
Results 1 to 18 of 18
Thread: Microchip AN615
    Jun 2006
    Bangalore, India
    Question Microchip AN615
    This application note features a 24 hour, 7 segment LED clock...
    How can i modify to make it a 12 hour clock ???
    AN615 --> http://ww1.microchip.com/downloads/e...tes/00615b.pdf
    Jan 2006
    Istanbul
    I think that if you make one on your own using PBP, it would take less time compared to modifying AN615.
    Search the forum.
    Wink Few changes ....
    Hi, Shahid
    Just have a look to listing lines 79 and 80
    Values Hour_HD_Max to be changed from 2 to 1, and Hour_LD_Max to be changed from 4 to 2 ...
    Note Interesting lines are 300 - 330 ...
    that might work like that ...
    No, no, no flowers ... thanks
    Jun 2006
    Bangalore, India
    Exclamation
    Thanks Acetronics, i'll try that out.
    But sayzer, i want to use a PIC16C54A. It does not have TMR0 interrupt.
    I have to mux 4 displays, check 4 buttons and keep accurate time.
    How can i keep track of time without the interrupt???
    Is there a way to keep time accurately without using hardware interrupts and do the rest of the stuff in PBP???
    I have made a clock using a F84 and TMR0 interrupt...
    Now i want to do the same thing without the TMR0 interrupt in PBP...
    Unhappy 16C54 >>> "newer pics"
    Hi, Shahid
    You're so right not to move to other Pics ... I tried some times ago from a 16C54 to a 16F84 ... ( was a " Berliner clock " !!! )
    Result was not that !!! The differences between program counters and adressing make things really tricky ... possible to do, but very high upon my Pic's knowledge !!!
    One thing about your program, I didn't tell you anything about PM and AM ...
    if you want to use the alarm function, you'll have to add a flag for that ... look carefully at the digit overflows section : there are lines where hours units are cleared after hours tenths overflow : just toggle your flag here !!!
    Of course, add a flag check to digits check for alarm raising ...
    Jan 2006
    Istanbul
    Ali,
    I guess you are targeting a low cost solution by selecting PIC16C54.
    Am I right?
    Edit: Ok. I just found this in your other post.
    "I dont want to spend too much cash on erasable PICs cause once i give away the projects the IC will never be erased again..."
    In this case, are there any other factors that make you use this chip?
    Mar 2006
    Hyderabad (India)
    Quote Originally Posted by shahidali55 View Post
    Hi, it is Sarma from Hyderabad India
    today i saw one site
    http://www.josepino.com/pic_projects...?led_clock.jpc
    where 12hour mode clock is described
    please see it for a difference and for appreciation
    Sarma
    Jun 2006
    Bangalore, India
    Smile
    Hello Sarma,
    The link you have posted , was infact my first microcontroller project.
    Before i came across this project, i knew nothing about microcontrollers.
    I simply built it. and guess what it worked!!!
    But that was a long time ago. As i was amazed after making this project,
    i just went on learning more and more about mcu's with the help of the net.
    Now i have re-written the code for this clock (as i couldn't get the original code), with more features such as battery back up, and even a night power save mode(as it runs on solar power)).
    This project by Josepino is an excellent one ! ! !
  1. Microchip Code Issues
    By Destovi in forum General
    Last Post: - 20th March 2008, 14:32
  2. PBP is no longer a stranger to Microchip
    By MarioC in forum mel PIC BASIC Pro
    Last Post: - 12th March 2008, 23:59
  3. Microchip Ethernet controllers
    By Philip in forum Documentation
    Last Post: - 2nd November 2007, 02:30
  4. Replies: 1
    Last Post: - 22nd June 2007, 01:57
  5. Microchip PIC silicon Revs's
    By fbraun in forum mel PIC BASIC Pro
    Last Post: - 1st March 2005, 16:07
