LCD serial backpacks
Results 1 to 40 of 68
    There is a section in the DT_INTS-14.bas file that has to be adjusted for the chip you are compiling for.
    I wish I could make it automatic, but there's no way to do that.
    For a 16F628, it doesn't have any General Purpose RAM in BANK3. So you have to comment out the wsave3 variable in this section.
    wsave       var byte    $20     SYSTEM      ' location for W if in bank0
    ;wsave       var byte    $70     SYSTEM     ' alternate save location for W
                                                ' if using $70, comment out wsave1-3
    ' --- IF any of these three lines cause an error ?? ----------------------------
    ' -- It depends on which Chip you are using, as to which variables are needed --
    wsave1      var byte    $A0     SYSTEM      ' location for W if in bank1
    wsave2      var byte    $120    SYSTEM      ' location for W if in bank2
    ;wsave3      var byte    $1A0    SYSTEM      ' location for W if in bank3
    The 628 also has Access RAM at address $70 which can be accessed from any bank.
    So commenting everything and uncommenting the $70 variable will work too.
    Either way will work ... take your pick.
    ;wsave       var byte    $20     SYSTEM      ' location for W if in bank0
    ;wsave1      var byte    $A0     SYSTEM      ' location for W if in bank1
    ;wsave2      var byte    $120    SYSTEM      ' location for W if in bank2
    Aug 2009
    I'll report to you. Thanks
    Aug 2009
    Well, beautiful. I comment out the 3 wsaves and everything came out as planned. I tested the 628 on my breadboard and the led blinked as expected. After that triumph I load your Serialin (I called Parallel to Serial) program and compiled it. I got one error only
    “Error [118] C:\program~1\mecanic~1\mcs\parallel~3 asm 200:Overwriting previous address contents(2007)” As always I try to find that error on the posts and I did but I don’t understand how to fix it. Thanks.
    Quote Originally Posted by timseven View Post
    I think you've found just about every possible problem.
    With the following advice from mister_e, I'm sure you'll reach the finish line.
    http://www.picbasic.co.uk/forum/show...=6775#post6775
    Aug 2009
    I got it!!! It complied perfectly and now comes the hardware test. I’ll do the setup and let you know how it worked. I think the worse part is over. I thank you and indirectly to Melanie, Steve and many others that post their problems and solution in this forum. I want to learn all about these unique interrupts from the bottom up. I’ll be around here for some time. TimSeven
    Great, and don't forget Joe S.
    It's his serial backpack program.
    Jul 2007
    while it's alive..
    Darrel, i've made changes as per your recommandation,
    So, the skipchar label down here take care of characters not to be sent to LCD.
    that works!
    and then I had the *brilliant* idea to add something else...which failed.
    I know we're, but not sure why.
    Next I wanted to disable interrupt while I do my little LED dance at start, and send some message on the LCD.
    It seems like the code will stop at > ; @ INT_ENABLE RX_INT; this seem buggy...
    Do you see why I couldn't disable/enable INterrupts at start, or at that specific place?
    I taught maybe i should put this in a sub routine?
    ; @ INT_DISABLE  RX_INT   ; Ignore input at initialisation
    HIGH LedPort	' Some visual sign of life for the PIC
    Pause 500
    LOW LedPort
    pause 50
    lcdout $FE,1	'LCD INIT
    lcdout $FE,2
    LCDOUT "LCD SERIAL - READY"
    PAUSE 300  		' Timeout for LCD to settle
    ; @ INT_ENABLE  RX_INT  ; this seem buggy...
    ' * * * *   Main program starts here * * * * * * * *
    loop:
            For i = 0 to 10 	' Delay for .02 seconds (10*2mS)
    	    	Pause 2   	' Use a short pause within a loop
    		Next i		' instead of one long pause
    skipachar:	; Will come back here if a char has to be skipped
    skipchar=0	; reset the flag so next char could be displayed
    display:			  	' dump the buffer to the LCD
    	IF errflag Then error	' Handle error if needed
    	IF index_in = index_out Then
              goto loop	' loop if nothing in buffer
    	GoSub getbuf	        ' Get a character from buffer
            if skipchar=1 then skipachar  ; with goto up there, skipping display of the last read char
            LCDOut bufchar	        ' Send the character to LCD
    		IF col > 20 Then	    ' Check for end of line
    			col = 1		    ' Reset LCD location
    			LCDOut $fe,$c0,REP " "\20	' Clear line-2 of LCD
    			LCDOut $FE,2	    ' Tell LCD to return home
    		EndIF
            if ShowRTC=1 then
              LCDOut $FE,$D4,"RTC ACTIVED"
              EndIF
    GoTo display	' Check for more characters in buffer
    ' Subroutines
    ;Disable				' Don't check for interrupts in this section
    getbuf:					' move the next character in buffer to bufchar
        index_out = (index_out + 1)	' Increment index_out pointer (0 to 63)
    	' Reset pointer if outside of buffer
    	IF index_out > (buffer_size-1) Then index_out = 0
    	bufchar = buffer[index_out]	' Read buffer location
        if skipLCDComm>0 then
           skipLCDComm=skipLCDComm-1
        ;Routine for buffering LCD commands
        if (GrabBkLt=1) then
           ; WE have signal to watch for value for LCD backlight next
           ; LCDOut $FE,$94,"BACKLIGHT set:<",#bufchar,">"  ; for debug only
           HPWM 1,bufchar ,1250    ; Setting Pulse Mod to desired value
           	' Observe minimum FREQ for given OSC speed. 20Mhz is 1221Hz
           Low LedPort 	; Debug only
           GrabBkLt=0   ; All is done, signal to close the loop
           skipchar=1	; to skip displaying this char in main loop
        ;Following will trigger the routine up here on the next chr received
        ; but if skip if $fe has been called 2 shots ago
        if (bufchar=20) and (skipLCDComm=0) then  ; 14h, trigger for special LCD command
           HIGH LedPort  ; Debug only
           GrabBkLt=1  ; Signal to get the value of backlight level
           skipchar=1  ; ;to skip displaying this char in main loop
        ;Prevent value of 14h to be trapped for other command, we memorize previous call of $FE (254)
        if bufchar=254  then
           skipLCDComm=2 ;
      @ INT_ENABLE  RX_INT
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. Please help with EDE702 - Serial to LCD interface
    Last Post: - 30th October 2008, 03:48
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. Serial LCD
    Last Post: - 15th November 2007, 09:31
  5. Need help with LCD number display.
