16f716
Results 1 to 4 of 4
Thread: 16f716
    Sep 2005
    Default 16f716
    Is anyone using the 16F716 ? I'm having trouble getting one to start up. A new project design uses one of these and it new to me. I have one on my proto board and it will not 'spin up'. Vdd and Vss are correct - MCLR tied high - 4 Mhz xtal w/22 pf caps - all the normal stuff. It will program BUT excatly every other time the programming attempt will end with an error that says "Code Programming Error at 0003". Using MCSP and ME Labs programmer. Here is the test code:
    @ device pic16f716, XT_OSC
    @ device pic16f716, WDT_OFF
    @ device pic16f716, PWRT_ON
    @ device pic16f716, BOD_OFF
    @ device pic16f716, PROTECT_OFF
    @ device pic16f716, VBOR_25
    Led var PORTB.3
    trisa = %11111111
    trisb = %00000000
    HIGH Led
    low led
    I've tried the other option for the last @ device line (VBOR_40) with no joy.
    Am I missing something in the data sheet about this PIC?
    Jan 2006
    Istanbul
    What do you mean by "MCLR tied high" ?
    No resistor? did you directly connect it to Vdd?
    Also, BOD_OFF and VBOR may be having a conflict associated with your MCLR.
    Did you check the data sheet for it?
    Sep 2005
    MCLR tied high through 10K resistor - also tried 4.7K.
    Different combinations of the @ device tried.
    Been going through the data sheets all morning.
    After all that I did figure out how to make the chip work. I'm using ICSP and after the chip is programmed nothing works including the oscillator until the power supply is cycled off and back on. I've worked with a couple of dozen different types of PICs and this is the first time I have encountered this.
    mwhatley, Do you have a scope? If so put it on the power supply and see if it is comming up within 100 Ms. If not that may be the problem. Also I would shut off the BOD or set it for the lowest setting. I would also lower the caps around the xtal to about 18 Pf.
  1. ADC setup for 16F716
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 12th November 2009, 02:39
  2. 16f716
    By amit28 in forum mel PIC BASIC Pro
    Last Post: - 28th November 2007, 17:56
  3. PIC 16C716 vs 16F716
    By droptail in forum General
    Last Post: - 21st August 2007, 18:25
  4. analog inputs on 16F716
    By schwinn_rider in forum mel PIC BASIC Pro
    Last Post: - 6th October 2005, 04:07
