odd 2550 behaviour
Results 1 to 11 of 11
    If 'alldigital' fixed it, then you're on the wrong forum!
    Ok I add 'alldigital' to my code and I compile and it works, but its not a supported command.......
    Scary........
    Ok save the hex, recompile without the 'alldigital' and compare the hex, no difference............
    Damn these chips!
    I'll just go sit in a corner for a while and rock back and forth.
    Jan 2006
    Istanbul
    f_lez,
    To make it clear, "alldigital" is not a command of PBP's.
    It is a command of another compiler.
    Thus, one should avoid posting "things" about another compiler on this forum.
    That is what Melanie kindly meant.
    claxon1's Avatar
    claxon1 Guest
    chill down sayser,
    and read the posts carefully.
    ps:
    I'm sure if Melanie would need a parrot she'll buy one
    cheers
    i suggest our friend open the PIC datasheet in section 21(analog converter) and 22(analog comparator)
    From there, you have to find how to disable AllAnalog stuff to make your i/o AllDigital.
    Claxon1... you should read and write better the name of Sayzer
  1. Strange Behaviour - Simple code+DT_INT+16F676
    Last Post: - 17th February 2010, 18:53
  2. Strange Serout Behaviour
    By bluesmoke in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 04:12
  3. Is Number Odd?
    By T.Jackson in forum Off Topic
    Last Post: - 11th June 2008, 17:53
  4. Strange behaviour from PIC16F877 on TMR0
    By mikebar in forum mel PIC BASIC Pro
    Last Post: - 19th August 2006, 01:31
  5. odd? network problem
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 30th April 2004, 18:33
