Bookmark support for the PBP Editor?
Results 1 to 13 of 13
    Talking Reinventing the wheel ...
    Hi, Muskut
    I Think ... Using INCLUDE could do exactly what you want !!!
    Heuuuuuu, " RTFM " page 22 ... for details.
    I Also found it in MCS Help .... Boooooo !!!
    Jul 2005
    INCLUDE is different from BOOKMARK.
    INCLUDE can be a solution but its not my question's answer.
    I want to mark a special line in my source code and I want to go there when I want by a shortcut
    Talking reinventing the Bicycle ...
    So, Just place a label !!! only for that purpose ...
    You'll find it in the left window !!!
    Then a double click will do your (...) wishes ...
    PS: Copy/Paste will be enough then ... instead of INCLUDE.
    Lightbulb Just so as I understand . . ? ? ?
    Quote Originally Posted by Acetronics
    I thought code following a label was confined to the custody of that label, like in a sub program, NOT SO ?
    When you drive your car on the highway... have you to take all exit?
    You can have 2019823498723563275642396456872 label but use only 100.. no harm, no preblem, no nothing.
    Or maybe i miss something in here?
    Default ? ? ? ? ?
    Quote Originally Posted by mister_e
    So if you do this it won't interrupt your code . . .
    Do something useful
    if ! useful then
    Bookmark1:
    do something other
    Won't it simply stop when the label Bookmark1 is reached and not finish and
    loop?
    Default Hi,Joe
    Undersand A label is just a help in the editor ... better you to understand what you do.
    When compiler sees Goto " labex x" ( i.e. ) it just replaces "label x " by the corresponding Hex program line number ... just as when you call a variable " gremlin " it juts replaces " gremlin " by its location in the memory.
    The best proof is to uncompile hex programs : you won't find any labels nor variable names ... just line numbers and memory locations !!!
    No statement referring to labels or variable names = no effect on hex program...
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
  2. PBP PIC32 series support?
    By foss in forum mel PIC BASIC Pro
    Last Post: - 18th August 2008, 12:10
  3. PBP External Memory Bus Support
    By ALFRED in forum mel PIC BASIC
    Last Post: - 25th December 2006, 08:42
  4. PBP Editor Wish List:
    By blainecf in forum PBP Wish List
    Last Post: - 12th July 2006, 21:07
  5. Compiler differences between PBP 2.33 & 2.46
